SR45 amplifier
debk · 220778
Offline braubeat
Reply #390 on: November 04, 2013, 05:00:02 AM
Offline howardnair
Reply #391 on: November 04, 2013, 05:36:47 AM
ok so the side with the large resistance is the primary side-the exo45 is handwritten--but there are no dots-on the primary side both red and blue come out of the transformer at the same distance from the coil--on the output side one wire obviously comes from the inner part of the coil-i will post on the mq site thanks--howie
Offline johnsonad
Reply #392 on: November 04, 2013, 06:14:08 AM
The dots are used on lug connections. You have flying leads.
Offline howardnair
Reply #393 on: November 04, 2013, 09:56:26 AM
aaron -thanks-i should know these things by now-i still am not certain what lead goes where-i suspect that the red to the plate and blue to ground and clear to positive and black to neg-being they are 550 for the pair i would like to be certain-i am surprised how much real estate i need for this-output transformer,large plate choke, triad power choke,grid choke and output trannie times 2 -i am using jensen radial style caps which are large -a mundorf m-lytic cathode bypass cap-again times 2 -plus all the other things needed-rt now it is all layed out on 1 piece of poster board-i am not sure whether it will be 1 amp or 2--this is my first scratch build-so it is fun but i am a little nervous-if put on one chassis are there any special cautions between the left and rt sections-
Offline johnsonad
Reply #394 on: November 04, 2013, 11:35:45 AM
It's best to ask MQ questions in the MQ forum or email Mike directly if you are not sure.
Online Paul Joppa
Reply #395 on: November 04, 2013, 02:41:41 PM
My mnemonic is the "blue plate special" - an old diner term that has stuck in my head. Blue to the plate (i.e. high AC signal voltage). For series feed transformers the red goes to the high voltage supply; for parallel feed it goes to AC ground; in this circuit that would be the cathode. There is a parafeed cap in one of these lines of course! Note that whether the red lead goes to B+ or to ground, the important thing is that it has near zero AC signal voltage.
Reply #396 on: November 05, 2013, 04:47:45 AM
Paul,
From what I know of transformers it will work either way but swap absolute phase on the output.
However, wiring it as it should be yields lower noise.
Is that right?
Online Paul Joppa
Reply #397 on: November 05, 2013, 10:45:50 AM
I don't know all the reasons for choosing a polarity, but I'm pretty sure there are more than one.
Offline howardnair
Reply #398 on: November 07, 2013, 12:47:47 AM
ahhh!!-Paul--the blue plate special it is!!-mike got back to me and the blue goes to the plate and red to ac ground-and black is ground on the secondary-and here is a little read on the blue plate special
http://en.wikipedia.org/wiki/Blue-plate_special
Reply #399 on: November 07, 2013, 01:26:20 AM
Howard,
Now Paul should reveal what BPC stands for.
He has before, it isn't a secret but it is funny and appropriate.
Offline johnsonad
Reply #400 on: November 07, 2013, 01:36:00 AM
You mean the Brainiac Plate Choke? I wish Mikey would make a run of them.
Reply #401 on: November 07, 2013, 02:50:48 AM
YUP!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2Fcongrats.gif&hash=8537e933ba501766e863d5aabbaca0ebcaf2719f)
Online Paul Joppa
Reply #402 on: November 09, 2013, 10:25:10 AM
Haha! I acquired that nickname back in the old VALVE days when I would work out operating points in my head. I don't think anybody has used it in the last 10 years though. :^)
Reply #403 on: November 09, 2013, 11:09:11 AM
Nowadays we call Peej "I'llbebackwithananswerafterathoroughanalysisiac", and the products have improved vastly because of it. But it's kind of a crappy name for a choke.
Offline howardnair
Reply #404 on: November 10, 2013, 12:55:28 AM
well!-it being a choke it is a form of audio-erotica
