SR45 amplifier
debk · 221071
Offline braubeat
Reply #390 on: November 04, 2013, 05:00:02 AM
Offline howardnair
Reply #391 on: November 04, 2013, 05:36:47 AM
ok so the side with the large resistance is the primary side-the exo45 is handwritten--but there are no dots-on the primary side both red and blue come out of the transformer at the same distance from the coil--on the output side one wire obviously comes from the inner part of the coil-i will post on the mq site thanks--howie
Offline johnsonad
Reply #392 on: November 04, 2013, 06:14:08 AM
The dots are used on lug connections. You have flying leads.
Offline howardnair
Reply #393 on: November 04, 2013, 09:56:26 AM
aaron -thanks-i should know these things by now-i still am not certain what lead goes where-i suspect that the red to the plate and blue to ground and clear to positive and black to neg-being they are 550 for the pair i would like to be certain-i am surprised how much real estate i need for this-output transformer,large plate choke, triad power choke,grid choke and output trannie times 2 -i am using jensen radial style caps which are large -a mundorf m-lytic cathode bypass cap-again times 2 -plus all the other things needed-rt now it is all layed out on 1 piece of poster board-i am not sure whether it will be 1 amp or 2--this is my first scratch build-so it is fun but i am a little nervous-if put on one chassis are there any special cautions between the left and rt sections-
Offline johnsonad
Reply #394 on: November 04, 2013, 11:35:45 AM
It's best to ask MQ questions in the MQ forum or email Mike directly if you are not sure.
Reply #395 on: November 04, 2013, 02:41:41 PM
My mnemonic is the "blue plate special" - an old diner term that has stuck in my head. Blue to the plate (i.e. high AC signal voltage). For series feed transformers the red goes to the high voltage supply; for parallel feed it goes to AC ground; in this circuit that would be the cathode. There is a parafeed cap in one of these lines of course! Note that whether the red lead goes to B+ or to ground, the important thing is that it has near zero AC signal voltage.
Reply #396 on: November 05, 2013, 04:47:45 AM
Paul,
From what I know of transformers it will work either way but swap absolute phase on the output.
However, wiring it as it should be yields lower noise.
Is that right?
Reply #397 on: November 05, 2013, 10:45:50 AM
I don't know all the reasons for choosing a polarity, but I'm pretty sure there are more than one.
Offline howardnair
Reply #398 on: November 07, 2013, 12:47:47 AM
ahhh!!-Paul--the blue plate special it is!!-mike got back to me and the blue goes to the plate and red to ac ground-and black is ground on the secondary-and here is a little read on the blue plate special
http://en.wikipedia.org/wiki/Blue-plate_special
Reply #399 on: November 07, 2013, 01:26:20 AM
Howard,
Now Paul should reveal what BPC stands for.
He has before, it isn't a secret but it is funny and appropriate.
Offline johnsonad
Reply #400 on: November 07, 2013, 01:36:00 AM
You mean the Brainiac Plate Choke? I wish Mikey would make a run of them.
Reply #401 on: November 07, 2013, 02:50:48 AM
YUP!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2Fcongrats.gif&hash=8537e933ba501766e863d5aabbaca0ebcaf2719f)
Reply #402 on: November 09, 2013, 10:25:10 AM
Haha! I acquired that nickname back in the old VALVE days when I would work out operating points in my head. I don't think anybody has used it in the last 10 years though. :^)
Reply #403 on: November 09, 2013, 11:09:11 AM
Nowadays we call Peej "I'llbebackwithananswerafterathoroughanalysisiac", and the products have improved vastly because of it. But it's kind of a crappy name for a choke.
Offline howardnair
Reply #404 on: November 10, 2013, 12:55:28 AM
well!-it being a choke it is a form of audio-erotica
