SR45 amplifier
debk · 220839
Offline johnsonad
Reply #435 on: March 23, 2014, 08:22:41 AM
Paul, forgive me but are these going to be mono blocks or a stereo amp?  I can't remember which way you decided..
Reply #436 on: March 23, 2014, 01:22:11 PM
Because of the extensive new circuitry, the chassis plate is 10 by 16 inches for a monoblock - somehow I think a 16 by 20 inch chassis would be a little clumsy!
Offline xcortes
Reply #437 on: March 23, 2014, 02:25:57 PM
And there's not enough room for my tl 404s!
Xavier Cortes
Offline dth31
Reply #438 on: March 23, 2014, 05:17:02 PM
Music to my ears, literally and figuratively!
Offline johnsonad
Reply #439 on: April 04, 2014, 04:00:03 PM
What's the word Paul, how goes the build?
Offline johnsonad
Reply #440 on: June 07, 2014, 06:07:49 AM
Hi Paul, how goes the project?
Offline fullheadofnothing
Reply #441 on: June 07, 2014, 07:11:25 AM
PJ came over to the island this week to pick up a bunch of parts. I believe they were mostly for power supply testing (big resistors to simulate the load, etc.), but output iron and a sizeable chunk of wire was picked up as well. It is my understanding that the power supply is being built on the chassis rather than breadboarded, so the amp must be starting to look like an amp!
Reply #442 on: June 07, 2014, 08:05:05 AM
PJ came over to the island this week to pick up a bunch of parts.  .  .  .
I hadn't realized before that PJ wasn't local.
Reply #443 on: June 07, 2014, 08:31:54 PM
Semi-local - door-to-door is about 90 minutes, longer in the summer when the ferries are full of tourists.
Josh's description is accurate. I need to put the fully loaded PSU output on the scope to know which regulator chips I can use for the filaments, and to know how much current I can take out without overheating the PT-7. Then I can finish the second large PC board, which has all the heat sinks.
I had hoped to do all that without using the full chassis, but there are so many wires with high voltage or current it just looked like a disaster waiting to happen, so I'm doing it the slow but clean way. Not really my natural style; there's a reason Doc doesn't usually let me build stuff by myself  :^)
Offline johnsonad
Reply #444 on: June 08, 2014, 04:21:06 AM
Tha K's for the update and keep one hand on your pocket ;)
Offline dth31
Reply #445 on: June 11, 2014, 12:40:48 PM
Hi PJ.  Thanks for all the updates on the SR45 amp project--we appreciate it!
A quick question--have you and Doc decided for sure whether this amp will be an actual BH product?
Reply #446 on: June 11, 2014, 01:49:32 PM
We have not talked strategy at all.
But I expect it will follow some non-traditional path, like crowdfunding or limited production run. Like the DAC, it's not cheap and will appeal to a smaller audience than our more mainstream products. I can see a semi-kit also - the main PC board will be pretty large (for Bottlehead) and has an awful lot of components on it, which will make debugging through the forum a challenge. Dynaco did this back in the day.
Offline dth31
Reply #447 on: June 11, 2014, 04:07:19 PM
Appreciate the info.  Thanks!
Offline johnsonad
Reply #448 on: July 26, 2014, 02:44:56 PM
Hi Paul, how's the build coming?  Any updates?
BTW, this thread has been on going for two years now :)
« Last Edit: July 26, 2014, 02:48:16 PM by johnsonad »
Reply #449 on: July 28, 2014, 12:10:22 PM
Back-ordered parts (from March or so!) finally came in a couple weeks ago.
Yeah, it's going slow - I keep getting distracted with other designs, most of which have not yet come to the point where we want to say anything about them.
