Resistance Check later followed by a voltage check :)
Johnman1116 · 8751
Offline Johnman1116
Resistance:
Terminal: Me: Bottlehead
1: 1: *
2: 1: *
3: 0: 0
4: 1: *
5: 1: *
6: 2.4: 2.4
7: 2.8: 2.9
8: 0: 0
9: 2.8: 2.9
10: 2.4: 2.4
12: 0: 0
13: 1: * to 270
14: 0: 0
20: 0: 0
22: 1: 0
B3: 2.8: 2.9
B6: 2.8: 2.9
RCA
GND: 0: 0
Center: 86.3/96.2: 2.9/2.9
I am thinking that something is not connected fully but is lame because i checked everything with a continuity reader.
I have applied the revisions: terminal 4 to 14U, but not the start up voltage mod.
also probably a very dumb question but it doesnt matter if i use the lower or upper terminals right? I figured out what those U's and L's halfway through lol.
Edited:
Assuming that the "1"  reading is an infinite reading, the only readings that are off is the 22nd terminal and possibly the 13th.
The thing is there is nothing attached to terminal 22 so a reading of "1" would make sense, in this case being an open circuit.
« Last Edit: June 21, 2012, 09:19:13 AM by Johnman1116 »
Reply #1 on: June 20, 2012, 11:57:04 AM
First, lower and upper terminals are connected with metal.  They are one and the same when measuring resistance and voltage.  However, when measuring resistance first touch your meter leads together.  This is not going to be zero and is the resistance of your meter leads.  Subtract it from the readings that should be zero.  If you get something under one ohm consider that zero.
It is always a good practice posting the expected and those measurements that are greater than 15% out of spec.
Also, a good read:
http://www.bottlehead.com/smf/index.php/topic,1667.0.html
When you whittle it down to only the out of spec readings it will be easier to help.
Reply #2 on: June 20, 2012, 12:06:14 PM
Those 1s probably mean "I" = infinity, i.e. a very high resistance reading. It's always worthwhile to take some time to learn how a given meter indicates various readings.
Offline Johnman1116
Reply #3 on: June 20, 2012, 03:23:25 PM
WOW so sorry, I was completely unspecific on my problems. Yes I know about the 15% margin of error. I was actually going to post only my problem readings but I thought you would have preferred all of them.
The readings that are bothering me are the ones that are "1": 1,2,4,5,13 and 22.  I thought a reading of 1 was either the setting is too low or the circuit was open.
I went through the manual and did not see anything about "Infinity" but I thought that that just meant the circuit was open therefore the resistance is infinite.
Reply #4 on: June 20, 2012, 04:55:28 PM
Very lo res those seven segments, so numeral 1 and capital letter I look the same. Some meters say "OL" instead, which I guess means "over limit". Easier to understand anyway, as you only see that when you read something too high for the scale setting. One of the difficulties for us as a kit manufacturer is that there is not a standard display for these readings on DMMs (and some folks still use analog scales). So we can't just say "if the meter says 'OL' the reading is very high resistance or open" and assume that everyone will grok it.
Anyway, it's a lot easier for folks here to troubleshoot if they just see the terminal readings that are off. Otherwise we have to sort through all the readings and figure out for ourselves which ones are off before we can get to offering suggestions.
Offline Johnman1116
Reply #5 on: June 20, 2012, 05:41:23 PM
basically you are saying that I can move on?
Reply #6 on: June 20, 2012, 06:42:23 PM
I'm saying that if you have any resistance readings that are not to spec with the manual let us know what they are, what the value is supposed to be, and what terminal you measure them at. If they all are in spec, assuming that the 1 you see is an "infinite" reading, you are good to move on.
Offline Johnman1116
Reply #7 on: June 20, 2012, 07:28:31 PM
edited.
From the manual:
Overrange "1 or -1" is displayed
"1 = OPEN or infinite"
« Last Edit: June 21, 2012, 09:16:03 AM by Johnman1116 »
Offline Laudanum
Reply #8 on: June 21, 2012, 02:15:28 AM
Some meters really act funky when measuring resistance where a capacitor is connected.   Im sure you are aware thats what those * symbols are in the manual.  All my meters act a bit differently when measuring those terminals.   I have 3 meters, none of which are great. When in doubt with one, I just break out a different meter and usually get an answer that inspires enough confidence to move forward.
As I think was mentioned, you could read 1 ohm or even a couple of ohms due to the meter leads.  Some meters have a zero function to zero out the small resistance that the leads add.  Others, you have to subtract when measuring very low resistance.  Looking at T22 in your measurments, your meter is reading "1".  So, is that 1 ohm or infinity ?   ;D   If it's 1 ohm, there probably isnt anything to worry about.
T13, Im not sure what to think because you meter looks like it measured 1=infinity for some of the */capacitor measurments but that terminal is a little different because the manual states that it will fluctuate in that it should climb slowly to about 270K ohms.  Again, your meter may just act funky because of the capacitor.  I would try taking that reading a couple different times making sure you have real good contact with the terminals (preferably using some lead clips).
I know, not much help. Sorry.   Im not at all an expert in these things so I cant give a definitive go or no-go to the voltage checks.
Desmond G.
Offline Johnman1116
Reply #9 on: June 22, 2012, 09:39:21 AM
VOLTAGE
Terminal - Me - Bottlehead
1- 150- 90
7- 150- 100
A6- 150- 90
A8- 12.9- 1.5
Also I do not see the 12AU7 (smaller tube) light up but maybe I am mistaken. Also I do not see both LEDs light up. The one from middle to A8 does not.
Reply #10 on: June 22, 2012, 12:43:37 PM
Looks to me like the LED at A8 is in backwards.
Offline Johnman1116
Reply #11 on: June 22, 2012, 05:02:19 PM
Everything looks fine to me.
Offline Laudanum
Reply #12 on: June 23, 2012, 12:59:30 AM
You're voltage is good at B1?   Double check.
Desmond G.
Reply #13 on: June 23, 2012, 01:32:34 AM
Yup, installing them upside-down helps clear that up easily.
Looking at my schematic yesterday it seems that one side is not conducting.  You do have voltage at the plate of the driver tube so the circuit is clear to that point.  Usually it means that the cathode circuit is open somehow.  Try this, set your meter either to the lowest resistance setting or the diode setting.
This will test the diodes.  Measure resistance from the pin on the tube socket to terminal 3.  This doesn't touch the diode leads and proves the solder joints are good.
Measure one diode from tube pin 3 to T3, then swap the leads and measure.
Measure the other diode from tube pin 8 to T3, then swap the leads and measure.
In both cases above you should get a high resistance measurement one way and a low one the other way.  Since you have two diodes right there it will be easy to compare one channel to the other.
Edit:
If you find one or both LEDs open, infinite resistance, both ways retouch the solder joints.  By that I mean wet the soldering iron, touch it to the tube pin or center pin or terminal at ground (T3?) and when you see it become liquid count 1..2 and remove the soldering iron.  So just liquid and the heat off.  Too much heat can fry the LED.
« Last Edit: June 23, 2012, 05:29:07 AM by Grainger49 »
Offline Johnman1116
Reply #14 on: June 24, 2012, 09:03:20 PM
Well I did the diode test and tested the leads of the LEDs. The one connected to terminal 3 was fine (infinite one way and about 1.5 the other). The LED connected to terminal 8 was open and I touched them up using your method but still no go.
Do I need a replacement?
Thanks Grainger.
VOLTAGE
1- 150- 90
7- 150- 100
A6- 150- 90
A8- 12.9- 1.5
B1 - 150 - 90
B3 - 150 - 100
Thank Laudanum.
« Last Edit: June 25, 2012, 12:22:01 PM by Johnman1116 »
