Eros BUILD HELP NEEDED
haiku626 · 15655
0 Members and 6 Guests are viewing this topic.
Reply #30 on: July 16, 2012, 05:37:10 AM
You can trace wires from the other terminals I mentioned, or disconnect those terminals from the rest of the preamp. IF the board is not connected to anything else, and is correctly wired without shorts, then there can't be a short at R3 ...
Offline haiku626
Reply #31 on: July 16, 2012, 08:58:56 PM
Paul,
I removed the wires that are connected to the board one by one and took a reading after each wire was removed.  R3 reads about .2 at each step and when the C4S board was totally free of the amp, the resistor at R3 still reads .2
Flipping the board over and examining it closely with a magnifying glass, I still could not find any bridges that would cause a short; I even had my wife, who is younger and has better vision, look it over.  Other than this I wouldn't know what to look for in what is causing the short.  I am pretty much "stumped."
Removed from the board the resistor reads properly at 173.5.
Reply #32 on: July 17, 2012, 03:58:31 AM
First, let me say I'm sorry this has become such a frustrating problem! Happens to all of us, and we never get used to it ... but we will resolve it, one way or another!
The likeliest place for a short is between the "A" and "r" pads where the 2N2222 installs. Less likely is near the jumper which goes from bA to bB; the adjacent terminals marked "x" should not be connected to anything. Be sure to look on both sides of the board. Those are the only ones I can see.
If that doesn't help, I think you should contact Eileen, mention this thread, and ask for a replacement board and parts. Sometimes it's less work to do it again than the figure out what went wrong.
Offline haiku626
Reply #33 on: July 17, 2012, 05:44:56 AM
I would like to say that I am taking this as an invaluable learning experience.  I am very grateful for the support of all who have contributed, and this has been the driving force for me.  Along with that I have also had a sample of the Bottlehead sound that I will be rewarded with although the experience has come from just one channel.  A Conrad Johnson PV11 has been my phono source for the past 20 years; nice tubey sound but noisy.
Will examine the board closely in the areas that you mentioned this evening when I get home from work.
Reply #34 on: July 17, 2012, 06:07:56 AM
Don't feel rained on, as we used to say.  I have been building kits since 1965 and Paul Joppa had to tell me I swapped the input and output wires in my installation of C4S boards last week.
We all get to a point that we can't see what we don't see.  Chill out, have a cold, adult beverage and get someone else to look at it as you read out what should be connected where.
You are at the point that you can't see the forest for the trees.
And give a cold, adult beverage to the guy who finds the mis-wired element after he finds it.
« Last Edit: June 06, 2013, 11:02:47 AM by Grainger49 »
Offline haiku626
Reply #35 on: July 24, 2012, 09:07:41 PM
I hope none of you thought I had given up since I have not posted in a week.  I did have two other people look over my build of the boards which were found to be built as per instructed, and no obvious solder bridges were noted.  Why R3 is shorted is still a mystery.  Therefore, I took Paul's advice to order new parts, and rebuild the board.  I also ordered a replacement on/off switch that was received defective, and a Bottlehead Badge which I forgot to order initially.
There was small box in my mailbox when I came home Monday evening from the Queen.  I initially told myself that I would save the build for the weekend, but could not resist starting the board rebuild at 9:00 PM.  I had it finished and installed by 10:30 and did the voltage check.  Kreg was still a little high at 1.34VDC but a far cry from the former 4.91; all other readings were okay within the acceptable margins.  I wanted to but didn't dare hook up the Eros to my system to see if I had sound in both channels.  A failure would have devastated me and I would not have been able to go to sleep.
When I got home from work on Tuesday evening, I swapped out the defective on/off switch and hooked the Eros up to my Conrad Johnson preamp, and gave the Bottlehead Crack with Speedball upgrade the honor of the initial sound check instead of using my power amps and speaker set up.  I put the Neville Brothers "Yellow Moon" disc on my turntable and crossed my fingers as the stylus hit the vinyl.
Man, I never new what I have been missing for the past 40 years of listening to records!  The Eros soundstage was unbelievable, and its gain is very generous with my Soundsmith cartridge.  The bass was solid and deep, and the highs caught me off guard.  I guess I had become accustomed to the laid back sound of my CJ and the Eros had much more low end slam and sparkle on the upper end.  I am very impressed with the Eros and it's not even broken in; sort of reminds me of the Crack sounding very good without any break in time.  I would like to congratulate Paul Joppa, Doc, and the Queen on an exceptional audio component.
I would also like to extend a special thank you to Paul Joppa, Grainger, and Noskipallwd for their assistance when I had difficulties in the Eros construction.  The problem that I had with the board added a special challenge that provided a learning experience for me.  Again, thank you for the much appreciated support.
Offline Noskipallwd
Reply #36 on: July 25, 2012, 05:52:38 AM
Congrats on your success! I agree with your assessment of the sound quality, it does sound great right out of the box. It will get better though. Before I built the Eros I found myself listening to my digital rig more often, mainly for ease of use. Listening to vinyl most of the time now, thanks to the Eros.
Cheers,
Shawn
Shawn Prigmore
Reply #37 on: July 25, 2012, 08:44:04 AM
I'm with Shawn, after my Eros build I have hardly turned on the CD player.
« Last Edit: June 06, 2013, 11:01:29 AM by Grainger49 »
Offline azrockitman
Reply #38 on: June 05, 2013, 09:09:28 PM
This is a great read for someone expecting his new Eros.
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
