Greetings, and a couple of questions - New Eros Build
dhherring · 3653
Offline dhherring
Hello all.
I just received my Eros kit and first inventoried the components and read through the manual.
All components were in the kit, but a couple of the caps where not as expected on the inventory sheet.  Not real sure what circuit these belong in, but these caps appear to be the two that are installed on pages
66/67 of the manual.
I have one with a value of 1,20uFJ, the other 1,00uFJ.  Any problem here? (Here's a shot of the caps in question:)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.pbase.com%2Fdhodgeh%2Fimage%2F145266485%2Foriginal.jpg&hash=2d35cdec0f84620b29216830b70be8b9b971d010)
The other question I have (after reading the manual) is when to solder the drain wires to the center pin of socket D (ref. page 48 of the manual).  While I have yet to find where it is explicitly stated to solder these to wire to the center pin, in subsequent photos it appears that the wires are soldered to the pin.  Did I miss this in the book?
Thanks in advance for any input, and I'm looking forward to getting this and the Stereomour I have on order into my system.
Don
« Last Edit: August 08, 2012, 04:19:42 AM by dhherring »
Vinyl: Technics SL-1200GR2 w/Denon DL-110 -> Eros Phono Pre -> Stereomour -> Klipsch Heresys
Digital: Jriver MC/Tidal -> Schiit Bifrost 2/64 -> Mainline -> Sennheiser HD-650
Reply #1 on: August 08, 2012, 05:05:15 AM
Whew, that's an odd pair of caps.  The difference of .2uf between the pair will not cause any performance issues (they could actually measure the same if the 1.2uf cap is on the smaller end of its tolerance range and the 1.0uf is on the higher end).
As for the center lug of socket D, only those two drain wires land there, as soon as they're both on the lug, go ahead and solder it.
If you'd like a replacement 1.0uf Solen, it will be no problem to send you one, just e-mail queen(at)bottlehead(dot)com.
