PJCCS Installation instructions -Help
galyons · 5036
Offline galyons
  • Geary Lyons
on: September 23, 2012, 08:15:04 AM
Hope that this is okay to ask!!!  :-[  I built my recently purchased PJCCS for my Quickie.  I then set it aside to await the upgrade of my output caps and the subsequent burn-in, listen to learn the "new" sound.  So today I heated up the iron, put the Quickie "on the bench" to install the PJCCs.  Loaded the instruction CD into my computer and... CR@P!!  My computer won't read the CD, it just spins and does not register as being in the drive.  Tried a different BH CD, (Seduction C4S), and it came up without issue!
So...( again if it's okay?), could some one send me the installation pages from the instructions.  Don't need the build, just the install!  Would like to get this done today!!
And it started off to be such a nice Sunday.... ;)
Cheers,
Geary
Reply #1 on: September 23, 2012, 11:15:00 AM
You don't have to listen to the forming of output caps.  Look here and see how to do it before inserting into the circuit:
http://www.bottlehead.com/smf/index.php/topic,80.msg286.html#msg286
I'm sure that the Queen will send you a replacement CD-R, post haste, if you contact her Monday morning.
Offline galyons
  • Geary Lyons
Reply #2 on: September 23, 2012, 12:28:12 PM
You don't have to listen to the forming of output caps....
Agreed, I don't.  I pre-burn caps as described and/or with my Hagerman Frybaby. What I was doing was getting myself "aurally" burned-in", that is, getting familiar with the sound of the Quickie with the caps, first, before adding the PJCCS.
Cheers,
Geary
Reply #3 on: September 23, 2012, 01:25:09 PM
YGM
Reply #4 on: September 23, 2012, 01:44:14 PM
Got'cha!
Offline galyons
  • Geary Lyons
Reply #5 on: September 23, 2012, 02:04:20 PM
PB to the rescue!!!  Thanks so much!!
Cheers,
Geary
Offline galyons
  • Geary Lyons
Reply #6 on: September 23, 2012, 02:07:57 PM
Got'cha!
I appreciate your referral to the link all the same.  In system burn-in is a PITA, as well as uses up valuable "magic smoke" in the circuits!
Cheers,
Geary
