Hardwiring s.e.x. 2.1 for 8 ohms and balanced output?
Jim R. · 8199
Reply #15 on: May 06, 2014, 03:12:12 PM
Makes sense if you never need to switch it over again or use unbalanced headphones.   Are you adding a socket or just going to connect via the speaker taps?
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
Reply #16 on: May 06, 2014, 03:33:49 PM
Based on some discussion on a new thread I created about enlarging the hole in the plate, I think I'll stick with an adapter lead from the speaker taps.
Reply #17 on: May 06, 2014, 04:38:10 PM
...  Don't ask me to work out which terminal on the transformer is which, that would require a few diagrams and lots of head scratching....
Funny, thanks! You have no idea how much head scratching and how many diagrams it took before I could put that simple PC board together - and I designed the #$%^ transformer just so we could do this dance!
For 4 or 8 ohms on the SEX amp, the windings are in parallel and there is no center tap. Balanced lines is short for balanced-impedance, meaning the impedance to ground of each side is the same. So you need an equal resistor from each side to ground.
Offline Loquah
    • Passion For Sound
Reply #18 on: May 06, 2014, 04:42:02 PM
Sorry to keep asking this, Paul, but does that mean a 100 ohm resistor (for example) from each of the -ve pins to the chassis?
Reply #19 on: May 06, 2014, 05:04:52 PM
Yes, that's exactly what I meant by "an equal resistor from each side to ground" - assuming you also have a 100 ohm resistor from the positive to chassis ground.
Offline Loquah
    • Passion For Sound
Reply #20 on: May 06, 2014, 05:46:46 PM
OK, so there should be 4 resistors in total? One for each contact on the 4-pin XLR?
