Hardwiring s.e.x. 2.1 for 8 ohms and balanced output?
Jim R. · 8196
on: September 26, 2012, 05:33:02 AM
I know this is probably a long shot, but has anybody here wired their s.e.x. 2.1 for 8 ohms and balanced outputs?  If so, I'd love to know what the connections are for this.
I plan to build my kit with a mini 4-pin xlr in place of the tRS connector as the headphone cable I will be ordering will be a mini xlr, and then I'll make the necessary adaptors for TRS and 3.5 mm cans, but I want to run my HE-400s and HD-800s balanced.
Thans for any help,
Reply #1 on: September 26, 2012, 07:52:38 AM
Hello Jim,
You need only wire the output transformer for 8 ohm operation, then connect the transformer outputs to the 4-pin XLR.
The convention for the 4-pin XLR is as follows:
Pin 1 - L+
Pin 2 - L-
Pin 3 - R+
Pin 4 - R-
Next, acquire some low-ish impedance resistors (around 100 ohms) and connect one to ground from each of those pins.  Note - you may find that part of the operation easier if you connect these resistors to the ground tab on the XLR jack itself.
Reply #2 on: September 26, 2012, 02:52:36 PM
PB,
Thanks -- that seems simple enough! :-)
Thanks much,
Jim
Offline Todd R
Reply #3 on: September 27, 2012, 01:04:33 PM
Jim,
I have the impedance boards installed, but you might be interested in what I did with mine.
I can run TRS or 4 pin XLR http://www.bottlehead.com/smf/index.php/topic,3133.msg27985.html#msg27985
Reply #4 on: September 28, 2012, 02:39:48 AM
Hi Todd,
Thanks -- I'll take a look though right now my inclination is to use just one balanced connector and make adaptors for other types, both balanced and unbalanced.  This way I can demo the amp wiith anything that comes along and not have a top plate full of holes and connectors :-).
The other nice thing about adaptors is that if I need to attenuate certain sensitive headphones, I can build the attenuation network directly into the adaptor.
Offline Loquah
  • Accidental Tube Addict
    • Passion For Sound
Reply #5 on: May 06, 2014, 02:57:39 AM
Hello Jim,
Pin 1 - L+
Pin 2 - L-
Pin 3 - R+
Pin 4 - R-
Just confirming, does this mean 4 x 100 ohm resistors?
Also, what's the reason for needing these?
Reply #6 on: May 06, 2014, 04:22:55 AM
The output transformer secondary must be grounded for safety reasons. For balanced operation, this pseudo center tap is a convenient way to do so - the transformer itself has a center tap when wired for 16 or 32 ohms, but not for 4 or 8 ohms.
FWIW, all this is incorporated into the impedance switch board - though that's overkill for what you are planning here.
Reply #7 on: May 06, 2014, 05:46:21 AM
Loquah the impedance board is worth having if you use different pairs of headphones, i switch mine fairly regularly depending on what i'm using.
Offline Loquah
    • Passion For Sound
Reply #8 on: May 06, 2014, 12:39:08 PM
What headphones do you use >8 ohms for, Mark?
Reply #9 on: May 06, 2014, 01:28:41 PM
Grados or any 32ohm high sensitivity headphone.  The HD650's i use with 8ohms balanced, haven't done much testing with the HE-500's so i dont know if 4 or 8 will be best, i have also made up a balanced cable to try too.
Offline Loquah
    • Passion For Sound
Reply #10 on: May 06, 2014, 01:53:25 PM
Hello Jim,
Pin 1 - L+
Pin 2 - L-
Pin 3 - R+
Pin 4 - R-
Sorry, still trying to confirm - do I need resistors on + and - connections or just on the -ve?
Mark, in relation to your post, my understanding is that the S.E.X. outputs higher power on the 32ohm setting and potentially has a higher noise floor. That's why I'm figuring to stick to a hard-wired 8 ohm balanced setup because if it can comfortably drive my HE-500s then there's no need to go to the 16 / 32 ohm outputs. Am I missing something?
Reply #11 on: May 06, 2014, 02:13:25 PM
Yeah that's pretty much it.  I have never used the 16 or 32 ohms options, only 4, 8, balanced and unbalanced.
As for the resistors, all i can tell you is the kit uses 60.4ohm, i'm not even going to try and get my head around that layout again. Its all in here http://bottlehead.com/smf/index.php?topic=5043.msg48467#msg48467 , i added the schematic Paul posted into the initial post since it got lost.
Offline Loquah
    • Passion For Sound
Reply #12 on: May 06, 2014, 02:22:54 PM
Thanks Mark.
My limited understanding of how to read schematics leaves me in the unfortunate position of still not knowing whether the resistors are required on +ve and -ve or just on the -ve. I'll look at the impedance kit I have here for my friend's kit and see it the "real thing" makes more sense to me than the schematic.
Reply #13 on: May 06, 2014, 02:30:11 PM
LOL thats where i started looking at the PCB's and couldn't make head nor tale of it.  It was only when Paul explained how the two windings are joined together in parallel for 4 & 8 ohms, or in series for 16 & 32 ohms that it all started to make more sense.  So when in parallel there is a resistor from each winding joined together to create a center point which is grounded, and the other end of each winding becomes your + and - terminal for balanced operation.  Dont ask me to work out which terminal on the transformer is which, that would require a few diagrams and lots of head scratching.
Now you see why i fitted the impedance switch board with an XLR socket, changes are just a flick of a switch away, bit like the mainline.
« Last Edit: May 06, 2014, 02:31:51 PM by mcandmar »
Offline Loquah
    • Passion For Sound
Reply #14 on: May 06, 2014, 02:52:11 PM
Yeah. I hear you!
I'm reluctant to spend $80 plus shipping for switches that I will never, ever use (i.e. once they're set to 8 ohm and balanced) so would like to just wire it once and be done with it.
Reading the post above from PB, it certainly sounds like a resistor needs to connect each of the 4 XLR terminals to earth (or the body of the XLR socket in this case)
