Crack and Phono
karl · 3079
Offline karl
on: October 02, 2012, 03:09:09 PM
Does the Crack require a linestage to work with a phono preamp? I'm considering the Hagerman Bugle.
Regards,
Offline denti alligator
Reply #1 on: October 02, 2012, 03:22:42 PM
You won't need anything between the Bugle phone pre and the Crack, no. The Bugle sounds pretty nice for the price, so I'd say go for it.
- Sam
Offline Tubejack
Reply #2 on: October 02, 2012, 11:53:14 PM
I used a bugle before I had my Eros completed.  Works fine.
But since the Eros, it hasn't been back in the system since .... :)
There are 10 types of people in this world,
Those that understand Binary and those that Don't!
Offline Laudanum
Reply #3 on: October 03, 2012, 02:06:11 AM
Concur with the above.   I borrowed a Hagerman Cornet from the main system fed directly into Crack.  Then later built Seduction.   Both worked perfectly fine direct in to Crack.   I added FPIII with an eye toward adding an amp and speakers to this system.  But, not needing to swap cables was a nice benefit (I use 3 sources with Crack) while I work on the speaker setup.   I do take advantage of FPIII for a little more gain for phono sometimes but it isnt necessary.
Desmond G.
