Extech dc power supply
tsingle999 · 5713
Offline tsingle999
on: October 31, 2012, 12:13:44 PM
http://www.extech.com/instruments/product.asp?catid=39&prodid=211
I have a couple of these. Are they any use to anybody for tube stuff??
Bottlehead Stat headphone amp
Reply #1 on: October 31, 2012, 01:19:46 PM
Looks like they would make a good filament supply for breadboard work...John
Offline tsingle999
Reply #2 on: October 31, 2012, 01:42:17 PM
Anybody want one cheap thats going to use it?
Offline adamct
  • Maxxximum CAPacity Crack
Reply #3 on: May 26, 2013, 04:44:31 PM
I don't know if you still have these, but I could really use one. How much do you want for it? I bought a cheap one, but it is unreliable, so I'm looking for something better that won't cost a fortune.
Best regards,
Adam
Offline adamct
Reply #4 on: May 27, 2013, 02:37:31 PM
These are gone. Can anyone recommend a regulated variable DC power supply that is around $150 or less? My Bottlehead kits have gotten me interested in electronics, so I am working my way through various practice exercises. I need a regulated variable DC power supply. I can use something like this: http://www.amazon.com/Philmore-Multi-Voltage-Regulated-Power-Supply/dp/B004M45MHQ/ref=cm_cr_pr_product_top ($34) or even this: http://www.amazon.com/Velleman-Compact-Universal-Adapter-Supply/dp/B00068U44I/ref=cm_cr_pr_product_top ($19), but I'm wondering whether it is worth springing for something like this: http://www.amazon.com/KORAD-KA3005P-Programmable-Precision-Adjustable/dp/B0085QLNFM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1369683657&sr=1-1&keywords=variable+dc+power+supply ($105).
I don't want to overbuy and overspend if not necessary, but I'd rather not buy cheap now, and wind up buying the more expensive unit later anyway. What features should I look for? How useful are multiple outs? Any thoughts on this unit? http://www.elexp.com/tst_0033.htm#3002
Offline STURMJ
Reply #5 on: May 28, 2013, 12:05:52 PM
If you have a dead pc around the house, there are instructions online to convert the power supply into a bench dc supply.  But, the outputs are 12, 5, & 3 V only. These are the most common used in basic electronics ( not in tube audio though).  This could be a very cheap option ( assuming the power supply is not the reason for the dead compter) . Also I should note that these supplies are not the cleanest DC supplies but good enough for basic electronics.
