Upgrading Caps
markc2 · 6644
Offline markc2
on: November 04, 2012, 09:30:54 AM
Hi All,
I was wondering what capacitors people upgrade in the quickie. I have seen some ones that are bigger than the batteries ;D
Mark
Offline earwaxxer
Reply #1 on: November 04, 2012, 09:56:20 AM
Everything in the Quickie can be upgraded! Thats the beauty of it! The only limit is your pocket book, and your due diligence to research what said changes could make.
I would suggest you do a good search for 'Quickie' and 'capacitors' in the bottlehead forums. Much good discussion there.
Caps are a huge field of specialization for the audiophile. We each have our favorites. Most of us have stayed 'sane' in the kind of money we have put into a $99 kit. You can very easily spend a few hundred bucks on caps for the Quickie. I have found the expense worthwhile, in taking a good, but 'inexpensive' sounding stock piece of kit, to a real player in the tube or SS preamp catagory.
With that said, or course you now have the 300b pre to tantalize you!
Here are some cap reviews to wet your whistle!
http://www.enjoythemusic.com/diy/0708/capacitor1.htm
http://www.altavistaaudio.com/caps.html
http://www.humblehomemadehifi.com/Cap.html
http://www.10audio.com/sonicap_oimp_multicap.htm
http://www.goodsoundclub.com/PDF/capacitorshootout.pdf
http://www.enjoythemusic.com/diy/1108/capacitor2.htm
https://www.head-fi.org/t/284863/orgy-of-capacitors-the-cap-thread
http://www.laventure.net/tourist/caps.htm
http://jimmyauw.com/2009/08/18/extreme-capacitors-battle-2nd-session/#more-1009
http://www.tnt-audio.com/accessories/testing_capacitors_e.html
http://sound.westhost.com/articles/capacitors.htm
http://tech.juaneda.com/en/articles/electrolyticcapacitors.html
http://www.co-bw.com/Audio_High_End_Capacitors.htm
Eric
Reply #2 on: November 04, 2012, 10:43:24 AM
   .  .  .   I would suggest you do a good search for 'Quickie' and 'capacitors' in the bottlehead forums.  .  .  .
If you go to the Quickie folder first you only have to search for "capacitors."
Reply #3 on: November 04, 2012, 11:07:36 AM
Has anyone tried bypassing the high voltage battery bank? There is no special reason to believe that any battery is "better" than a good audio capacitor. You don't want an electrolytic; they do have some leakage and will drain the battery even when switched off, but a nice film cap could well have an audible effect. Personally I'd try 50uF, but I think as little as 10uF would be effective - if there is an audible effect.
Offline tuffy_puppy
Reply #4 on: November 04, 2012, 11:40:35 AM
grainger,  i see you have nicknamed yourself "old fart"  i disagree.  i don't think you are that old!  hahahahahaha,  best wishes,  don
Offline earwaxxer
Reply #5 on: November 04, 2012, 12:58:51 PM
Hey Paul - I kind of wondered about that. So the cap would be hooked up in parallel, or serial to the battery?
Eric
Offline Alonzo
Reply #6 on: November 04, 2012, 01:25:47 PM
**mn, and I thought after new interconnects I'd be done...would this be the same effect as adding a ceramic snubber for an AC circuit?
Alonzo
Reply #7 on: November 04, 2012, 03:52:03 PM
Parallel.
Reply #8 on: November 04, 2012, 04:23:34 PM
I would suggest attaching film caps across the tubes from the incoming "high voltage" to the circuit common, below the cathode cap and resistor.  The point of having a high speed film cap at the tube is to supply immediate energy to the circuit when needed.
Offline earwaxxer
Reply #9 on: November 05, 2012, 09:36:23 AM
So, I attached a 22uF Obligatto to the battery pack. If there was a 'change' in sound I'm not sure I have heard it. It didnt cost me anything, so I'll leave it. Granger's idea may prove to be positive. I'm too lazy to try it.
Eric
Reply #10 on: November 05, 2012, 10:18:58 AM
Grainger's suggestion is not different from mine - we just turned it into different words. Apologies if mine were unclear; it's been know to happen before ...
earwaxxer, thanks for the feedback. For teh record, do you have the CCS installed? Anyhow, I'll suggest you leave the cap in for a few weeks until you are thoroughly used to it, then remove it and see of you hear any change. Sometimes changes, like interconnects, have a preferred direction. (Sometimes not - I just want as much data as I can get!)
Offline earwaxxer
Reply #11 on: November 05, 2012, 12:30:32 PM
nope - I got the chokes. They may have the same effect as a cap. No? I do like my 2500mah NMH over my 50mah Lipo4 for the record.
Eric
