Advice on finish (and application) for top plate (& xformer bells?)
Downhome Upstate · 6917
Offline Downhome Upstate
UPS delivered my still boxed-up Stereomour kit today  ;D, and I'd like to paint or otherwise apply a nice, lasting finish on the top plate before assembly. Any thoughts/suggestions?
Thanks.
P.S. I haven't even opened the box yet, and so have no idea what the transformer bells look like. Are they a good candidate for this treatment too?
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Online Paul Birkeland
I'd open the box and check the stock plate finish first to see if you like it.  Leaving the plate unpainted has some advantages, as the factory finish hides scratches nicely.
The transformer cover really must be painted, I would toss it in the next time you run your dishwasher, then sand it down with some coarse steel wool to be sure all the oil is off.  Beyond that, a clear coat of polyurethane or epoxy-based spray paint will provide a good lasting finish.
You can spray that same paint on the plate chokes if you like.
Offline Tickwomp
If were to build anything new, I'd have the top plates powder coated!  If you can find the right shop, it's quick, durable, tons of finishes, and fairly reasonably priced!
Mach2 Mac Mini->Amarra Mini-> Chronos Athena USB Cable->Audio Note 4.1LE DAC->24ga Ag w/WBT0101ag ICs-> Audio Note L4 Remote->24ga Ag w/WBT0102Ag ICs-> Paramounts w/MQ Nickel Opts and EML 2a3 Mesh Plates->16ga Ag Bi Wire->Klipsch RF-7 w/DeanG Mods
Offline ODYOFAEL
I used some leftover automotive paint. I had some Honda paint code mixed for retouching. Also used 2K Automotive clear coat. I painted the bell and OT with wrinkle paint. As for the wood base, just go to OSH or Home Depot and chose from the catalog.(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi104.photobucket.com%2Falbums%2Fm172%2Fqctirecenter%2FBottlehead%2520and%2520Music%2520room%2FIMG_0582_zpsca8a8d54.jpg&hash=f1fdaa8a93f98449ac5d86c26cfda2d194c30c41)
Nice! The Darth Vader look . . .
"Too soon old;
   Too late schmart"
Mike P.
Offline coca
There are so many options. I have sanded and polished my top plates, then sprayed them with a clear, I have also sanded them and had them chromed, and some of them even copper plated. I have also had some of my trans. covers gold plated and copper plated.
Bernie.
Offline debk
i usually spray the top plate and transformers bells with copper hammertone paint
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline Reap
I like the dark look. Probably a great contrast to tubes lighting up too and probably settles in with it's surroundings as well.
Offline Chris
That wrinkle paint is nice.. I like it also..
I had another look at the steel brushwork Doc did on the top plate, and liked it so much I just shot the first coat of Rustoleum gloss clear.
When you paint the chokes, do you tape-off everything except the plain steel brackets?
"Too soon old;
   Too late schmart"
Mike P.
Damn! Has anyone besides me screwed up the paint job on the top plate?  Think I'm going to have to take the badly-applied finish down to the metal and tear up that nice wire brushwork.
"Too soon old;
   Too late schmart"
Mike P.
If you want to send the panel back I will rebrush it for you.
Hey, Doc. Thanks for the offer. I'd like to fix this myself, though. Any suggestions on the right drill attachment to use, and on technique?
"Too soon old;
   Too late schmart"
Mike P.
I'm going to try paint stripper first.
"Too soon old;
   Too late schmart"
Mike P.
The 'Orange' eco paint stripper spray I got at Home Depot worked pretty well. I was able to gently brush the stripper and lacquer residue off the top plate and then clean it with odorless mineral spirits, all without destroying Doc's wire brushwork. I'd give the result about a 9 out of 10.   8)
My Orcas are due on Christmas Eve; time to get building. Merry Christmas, everyone!
"Too soon old;
   Too late schmart"
Mike P.
