Stereomour in Burbank...Voltage Question
ODYOFAEL · 4441
Offline ODYOFAEL
on: December 04, 2012, 12:18:53 AM
I have just finished assembling my Stereomour. I have one question about the voltage reading. I took a picture of the sheet of paper so it would be clearer. I have attached pictures of the amp as well.
Regarding the low voltage reading...is this bad? Everything else is almost spot on. Also, I am driving a pair of Omega Super 3T speakers (94 db) and and is it normal that I am already at 3 o'clock volume position to reach normal listening level? My room is 10 x 12? Or is the low gain caused by the voltage I am getting at those terminals (2,14,OA and OB)? What could be the cause? Thanks in advance.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi104.photobucket.com%2Falbums%2Fm172%2Fqctirecenter%2FBottlehead%2520and%2520Music%2520room%2FIMG_0586_zps570862af.jpg&hash=6e0d2c6e7bb55f61cf10aab02687d856c5c1242e)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi104.photobucket.com%2Falbums%2Fm172%2Fqctirecenter%2FBottlehead%2520and%2520Music%2520room%2FIMG_0588_zps820a10e3.jpg&hash=b5260f17d7d82cfc9f5de0b483e91e38754d99f3)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi104.photobucket.com%2Falbums%2Fm172%2Fqctirecenter%2FBottlehead%2520and%2520Music%2520room%2FIMG_0594_zps5f901e10.jpg&hash=62b97057731979876d22a4ac49f099c787aac271)
Reply #1 on: December 04, 2012, 05:56:46 AM
Wow, this is actually a very interesting post.  If I had to make a guess about what's going on with your amp, I'd say that you have a 12AT7 that isn't quite a 12AT7.  With all other voltage spot on, the drop in voltage could equate to a tube with higher gain, and the volume control position is a possible indicator of this problem.
In terms of what this tube actually is, it's possible that it's a 12AX7 variant (7025 comes to mind).  More on relabeling can be found here:
http://www.vacuumtubesinc.com/VacuumTubesHallofShame.aspx
There isn't any harm to the amp to leave this tube in, but I'd e-mail Eileen about getting a replacement tube (queen ( at ) bottlehead (dot) com )
PS - your amp looks great, did you end up masking the plate chokes or painting the whole thing?
Offline ODYOFAEL
Reply #2 on: December 04, 2012, 07:41:16 AM
Thanks! Yes I did tape the OT. I was going to revove the cover but...=)  It turned out nice though.
Re: the voltage. I did re-check and they are almost spot on. Terminal 1,15,A2 and C2 getting around 380 though. Is that withing limits?
Reply #3 on: December 04, 2012, 08:18:24 AM
I suspect it's actually a 12AU7. Can you read the marking on the tube? 90-92v would be right on the nominal value for a 12AU7 at that operating point.
Reply #4 on: December 04, 2012, 10:32:10 AM
It would be good to double check the Kreg voltages, just to be sure.
That tube sure doesn't look like a 12AU7.
Offline ODYOFAEL
Reply #5 on: December 04, 2012, 06:21:10 PM
I swapped the unmarked tube (12AT7) that came with the kit with a 12AT7 Telefunken (also tried an RCA) and guess what, what used to be 92 volts went up to 230V. Sweet! Now at around 1 oclock volume, I am at my normal listening level. Thanks guys. I have called Bottlehead today and told them about it. The tube is on it's way. ;)
