Best under $1K phono stage(s) for DL-103R & Stereomour?
Downhome Upstate · 5606
Offline Downhome Upstate
on: December 13, 2012, 12:17:25 PM
Have a pair of Orca's on order. Looking for it all, of course, on the cheap. Microdynamics & great tone. Accuracy (that leading edge that detail freaks love) but not at the expense of musicality. (Hell, I don't even really know how to say this.)
In any event, given the Stereomour's front end, are we talkin' tubes or SS?  Dedicated MC or affordable MM + SUT?  Can I do this for less than $1K and be happy for a year (at least)? Love to hear from folks who have a 103 or 103R with the S-mour and didn't spend crazy money with the in-between electronics.
"Too soon old;
   Too late schmart"
    The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
Reply #1 on: December 13, 2012, 12:25:51 PM
I think you could do pretty well with the Seduction and a step-up transformer.  It looks like Denon has quite a few step up transformers available, and these two will fit well within your budget.
If you shop carefully (IE - get the Denon SUT used, maybe an AU-300LC), you could get an Eros and a step up transformer for right around $1000, which would certainly offer the best long-term performance and more flexibility in terms of how much voltage you get out of your SUT.
Offline ssssly
Reply #2 on: December 14, 2012, 12:57:14 PM
I have an Eros with an Altec 4722 based SUT that I use for my 103. Sounds great. With the Eros on sale and the price of 4722s you could easily do it for under $1K. Could also try making a Cinemag Blue Transformer SUT. Have been meaning to build one for a while to try it out but haven't gotten around to it. They are supposed to sound really nice as well.
Offline grufti
Reply #3 on: December 14, 2012, 05:42:25 PM
The Eros special is your very best bet. There are only three available. I have had my Eros since it first became available. It has never come out of my primary system since I finished it, well, except to get worked on some more. There are many good transformers available to bridge the gap [termination and gain] between your Denon 103 and the Eros
Reply #4 on: December 15, 2012, 08:39:58 AM
Just wondering if the combination of the Eros and the Stereomour might be too 'tubey' with a 'tone' oriented cartridge (i.e., not a detail monster) like the DL-103 or 103R.
"Too soon old;
   Too late schmart"
Mike P.
Reply #5 on: December 15, 2012, 09:22:53 AM
The overly euphonic "tubey" sound is not a persistent attribute of either kit, IMO, as a consequence of using active loads for the voltage amps.
Reply #6 on: December 15, 2012, 10:30:35 AM
Sounds good (pun intended). I have never heard either unit, and appreciate the info. Maybe when I get my Stereomour built I can find someone in northeast Pennsylvania, north or central Jersey or the greater NYC area who has an Eros they wouldn't mind hooking up to the amp.
"Too soon old;
   Too late schmart"
Mike P.
Reply #7 on: December 15, 2012, 10:40:09 AM
When you get your Stereomour up and running, you can do a little experiment to acclimate yourself to what the C4S does.  On the green PC board in the center, you can pop off each set of wires going to IA/OA and IA/OB, then temporarily solder a 52K/2W resistor between each pair of wires, then listen.
On amps where the C4S load is an upgrade option, we are often asked why they aren't included from the get go.
Offline grufti
Reply #8 on: December 16, 2012, 09:23:33 AM
The Eros is not tubey.
