12AU7 -> 6CG7 = WOW!
craigtone · 25880
Offline craigtone
on: December 15, 2012, 08:21:06 AM
I just sorted through my box-o-tubes and found a stash of about a dozen 6CG7/6FQ7's.  I did a Google search and found many preferred them over the 12AU7.  I myself have struggled with the 12AU7 over the years in my Foreplay III and the driver of my ST-70.  I have "compromised" on the RCA Clear Tops.
I dug up an old thread on the AA forums and modified my Foreplay III to use the 6CG7's with a grounded shield and I was blown away!  The bass bloomed and there is more depth to the sound (front-to-back soundstage).  Female vocals almost have an eerie 3-D sound to them now as well.
For those considering this upgrade, I give it 3 thumbs up (???)!  It only took about 30 minutes with a soldering iron:
1. Unhook heater wires from the 12AU7 tubes.
2. Unhook heater ground reference from Pin 9 of the one 12AU7.
3. Re-wire the heaters to Pins 4&5 of the 12AU7's (observe polarity!).
4. Tie the heater ground reference to Pin 4 of the one 12AU7.
5. Tie Pin 9 of both 12AU7's to the closest ground terminal (one used for cathode LED ground).
6. Replace 12AU7's with 6CG7/6FQ7's.
7. Enjoy!
Offline Nutube
  • AudioAddicted-RefuseRehab
Reply #1 on: January 17, 2013, 12:44:52 PM
hi
i am glad it sounds so good
i just used an adaptor and plug a pair of 6sn7  in and it was an improvement balanceced spectrum an more base definition
enjoy
FP 1,2,3, Seduction, 45, Paramount 300B, Paraglow2A3; Dehavilland 845, Eico pp 805,Adcom 555 mono, Sota star saphire ugraded Nova motor & bearings,  Et 2.5 carbon wand on Shelter 901, Koetsu rosewood Sig., on magnesium wand, grado sumiko etc. Custom Edgarhorn with Seismic sub
Offline earwaxxer
Reply #2 on: January 17, 2013, 02:18:29 PM
interesting stuff. Got to love this hobby...
Eric
Reply #3 on: January 18, 2013, 05:50:05 AM
Hmmmmmm, no resistor changes?  I remember one of the finest preamps I heard used a single 6FQ7 in each channel.  I might have to make an adapter and buy some tubes.
Offline earwaxxer
Reply #4 on: January 18, 2013, 02:37:20 PM
I always loved the days of alchemy. It lives in audio... You call me a dreamer - but I'm not the only one.
Eric
4krow
Reply #5 on: January 18, 2013, 04:02:11 PM
But isnt the heater voltage different on 6CG7(6 volts?) compared to a 12AU7(12 volts)
Offline galyons
  • Geary Lyons
Reply #6 on: January 18, 2013, 04:24:04 PM
The tube can be run in series, (12.6v) or parallel, (6.3v).
Cheers,
Geary
Reply #7 on: January 19, 2013, 03:47:16 AM
The FP 2 and III had a 6.3V heater winding with higher current.  For a 12AU7 the 12.6V heater arrangement draws 0.15A, the 6.3V heater wiring draws 0.3A, double what is drawn at the double voltage wiring.  There is no free energy but the center tapped heater allows for greater compatibility.
« Last Edit: June 20, 2013, 03:07:32 PM by Grainger49 »
4krow
Reply #8 on: January 19, 2013, 08:25:29 AM
gaylons/grainger,  Thanks. Now that makes sense.
Offline mike9186
Reply #9 on: March 18, 2013, 04:42:32 AM
I am going to give this tube swap a go this weekend.
It's been nearly 6 years since I've played with my Bottlehead gear (Foreplay 1 and Foreplay 3, Seduction and Paramours) and the system fired right up with nor problems! It is funny to see how my soldering evolved from the the original Foreplay and Paramours to the newer stuff. Overall the system is sounding kind of shouty...could be the speakers and the new environment they are in...it's too soon to tell.
Love this board
4krow
Reply #10 on: March 18, 2013, 06:28:15 AM
I too, have had the shout problem. In my case it was the speakers. Controlled that problem with device from Decware. Seems like it was called gizmo. Some kind of coupling transformer with a variable input, allowing different effects for different speakers.
Offline najo49
Reply #11 on: June 20, 2013, 02:55:42 PM
How about trading something for a couple of your excess stash of these tubes? interested? Jan Olsen.
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
