Quickie duo
earwaxxer · 4514
Offline earwaxxer
on: December 18, 2012, 02:46:55 PM
sorry if this is already posted - I couldnt find it - Quickie 'buffer' x2 pretty cool! -
Eric
Offline Alonzo
Reply #1 on: December 18, 2012, 05:38:03 PM
Eric,
Sorry for this dumb question but what does the second Quickie do?  I can't follow the input and output wiring, is it just for extra gain?
Alonzo
Alonzo
Offline proud indian
Reply #2 on: December 18, 2012, 09:17:38 PM
Same question. I thought the gain was pretty good with just one. What is it that you are hearing with the second one in line?  The only thing that I can think of is that you are using lesser gain on each, which means lesser clipping, in case you were going full tic on the single one.
shreekant :)
system 1. oppo, quickie,SEX 2.1 ( V cap), Decware DFR8 in ZOB cabs
System 2. Tascam cd200, Terra Dac,Zbox,Decware Zen amp(V cap) Lowther PM6A in Acousta horns.
Maple rack, Brass footers,Power conditioner, dedicated treated room, iso pads, plenty of tubes. All cables DIY.
Offline earwaxxer
Reply #3 on: December 19, 2012, 03:21:17 AM
Its a little crazy, but I'm using my Transporter as a pre-amp and the digital out is also attenuated. I'm using a long toslink to my MSB DAC to provide input to my Crown sub amp. I added the Quickies as an active boost because the DAC output is too low. Everything ends up on one interconnect to the Crown running in bridged mono. The Crown also has balanced inputs. Im not sure how to wire the Quickies to provide balanced output. Paul mentioned that I can use two Quickies to provide one balanced output - topic for another thread!
Eric
Reply #4 on: December 19, 2012, 04:27:01 AM
You lead a complicated life.......you may find that you are spending more money on booze than gear ;D
shreekant :)
4krow
Reply #5 on: December 19, 2012, 04:44:54 AM
Us crazy guys do things out of the box now and then. Sometimes it ends up in flames, or times it ends up in enlightenment. Half the fun iz the ride.
Reply #6 on: December 19, 2012, 08:48:11 AM
... Im not sure how to wire the Quickies to provide balanced output. Paul mentioned that I can use two Quickies to provide one balanced output - topic for another thread!
There is a good white paper on connecting balanced and unbalanced devices, on the Jensen transformer web site. Naturally they prefer transformer solutions, so apply your own grain of salt!
http://www.jensen-transformers.com/an/an003.pdf
Fig 2.1 is easy and usually works well.
Fig 2.4 it truly balanced - it's in the BeePre. But you have to know the output impedance, which is very different for different Quickie plate loads. For stock, about 2K, for PJCCS about 4K, with a choke you need a second choke per channel ...
Offline earwaxxer
Reply #7 on: December 19, 2012, 01:23:49 PM
shreekant :)
I definitely spend more money on booze than gear! They go good together though. - Hey Paul - thanks for the balanced info. It sounds like an interesting project! I may be forced to try it!
Eric
