more fp 2 questions
najo49 · 3878
Offline najo49
on: December 24, 2012, 06:11:34 AM
Is there instructions anywhere on the installation of the c4s boards? Also is there a schematic I can use to build the boards i have all the parts here. And is there any reason you could not insert the Od 3 in the power supply like the fp3? Its seems relatively easy. Thanks
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #1 on: December 24, 2012, 07:13:07 AM
FP-II has neither the voltage nor the current available to run a shunt regulator.
