Is my power transformer sticker on backwards? I don't have a terminal 2. See pic
Pfenning · 8645
Offline Pfenning
  • My knockoffs
    • This is the place
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi156.photobucket.com%2Falbums%2Ft23%2Fpfenningv%2Fphoto-1_zps4909a1b4.jpg&hash=d31e68b6f79b0648133aa6cbb5992ecd74357089)
It seems like the sticker was applied incorrectly. Can I just turn it 180 degrees?
Pfenning
Pfenning
Yes, that is backwards. The staff will be properly punished.
Offline saildoctor
Looks backwards.  I just cracked open my Tode and the label is on the other way.  You could check for continuity between each winding to confirm?
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
Offline Pfenning
  • My knockoffs
    • This is the place
Thanks, I'll flip it around.
Pfenning
Pfenning
On PT-3s and PT-7s the two terminals with the heavy wire (4 and 5) are the 6.3V winding. That's the point of reference the staff is supposed to use when orienting the labeling on the transformers, and what I used to check your photo.
