Tube Problem
ashneel · 2369
Offline ashneel
on: December 31, 2012, 07:12:02 AM
I've just finished building my Crack. Resistance Checks are done and fine.. My only problem is that the 6080 tube does not completely fit in..I've tried several times, but it feels like its blocked. It goes like half way through. Should like look for new tubes?
Reply #1 on: December 31, 2012, 07:14:03 AM
How hard are you pushing?
I'd grab that metal ring base and give it some pressure, it's likely that one of the pin receptacles in the socket needs some pressure to straighten out.
You can also look into each of the pin holes on the socket to see if there's some solder that snuck in there and is causing a blockage, or if one of the pin forks needs to be pressed out of the way.
Offline ashneel
Reply #2 on: December 31, 2012, 08:21:05 AM
Got it, applied more pressure on the meteal base and it seems that one of the pin was not straight. Thanks for the advice  ;) ..Going to get the voltages check tomorrow
