stereomour upgrade... then issues.
balancedtriode · 3293
Offline balancedtriode
on: January 01, 2013, 06:04:55 AM
recently I finished a overhaul of my stereomour, resistance checks are fine, but the leds on the center board don't light up and through my speakers it sounds like it is on, except no music comes out, It is possible I damaged the board because my iron slipped and hit a few components... :-X, should I just order a new board or is it possible to fix this?
Thorens TD-160 Custom(rebuilt by me) with SME 3009 arm
Bottlehead Seduction
Extended Foreplay-III (build underway)
Stereomour Power Amp conversion (Heavily Modded)
Klipsch Cornwalls' with Vertical Horns
Reply #1 on: January 01, 2013, 09:14:46 AM
Since the board has the problem, start with checking the voltages on the board terminals which connect off the board - IIRC there are eight(?)
Reply #2 on: January 01, 2013, 10:27:37 AM
checked the connections and realized a few wires snapped off the board ??? ??? thats what I get for trying a new type of solid core wire... it worked great for a moment the there were sparks near the 12at7 and one side of the 12at7 lights up brighter that the other, now only on channel is working, I feel like I have messed up the steromour this way before... time to go post hunting,
