Minor Channel Imbalance at low volumes
ashneel · 5432
Offline ashneel
on: January 18, 2013, 04:06:09 AM
At very low volumes, I get the impression that the right side of the HD650s sound a bit louder. My voltage and resistance checks are also all ok.
I've tested directly through my ipod, and it isn't headphone defect. I've also swapped the L/R channels, but it is the same.
Apparently analog potentiometers controlling volume, exhibit some degree of channel imbalance, at low volumes? Is that true. Can someone plz help
Reply #1 on: January 18, 2013, 04:19:47 AM
This is typical with a volume control that is low cost.  The tracking, i.e. matching from channel to channel, is poor when you don't spend upward of $30 for a pot.  There are quite a number of posts of Bottleheads who have improved upon the tracking and sound with a more expensive part.  Do a search on either volume control or pot in the Crack folder.
Offline ashneel
Reply #2 on: January 18, 2013, 04:27:36 AM
Thanks for the help and advice..I just wanted to know if that was normal, and not smthg I messed up during construction. It only occurs at very low volumes, not "normal" listening levels, so I'll be able to live with it  :P
Amazing how you get instant help on the Bottlehead Forum..Cheerz
Reply #3 on: January 18, 2013, 08:42:12 AM
You can also remove the red and white wires that go form the RCA jacks to the pot and solder in a pair of 100K resistors in line with each wire to attenuate the input to the pot.
This will mitigate some of the poor tracking at lower levels.
Offline Zimmer64
    • Blog
Reply #4 on: January 18, 2013, 10:46:06 AM
Had a similar problem with my Quickie at the time. Once I had put in an Alps pot (moderate upgrade cost), the problem went away.
Best
Mike
Offline ashneel
Reply #5 on: January 18, 2013, 10:40:54 PM
It is not actually bothering me..though can you link me to a decent and affordable pot? I'm sorry, I'm new to all this. Ebay would be quite helpful since I'm in Mauritius..
Offline Zimmer64
    • Blog
Reply #6 on: January 19, 2013, 08:39:34 AM
I bought an Alps RK27: http://www.alps.com/WebObjects/catalog.woa/E/HTML/Potentiometer/RotaryPotentiometers/RK271/RK27112A00AK.html
Here is a place in the UK: http://www.hificollective.co.uk/, but you get the Alps probably also on the bay.
Mike
Offline ashneel
Reply #7 on: January 19, 2013, 09:39:40 AM
Thanks mate, UK shipping to Mauritius is quite fast. Will these be ok?
http://www.hificollective.co.uk/catalog/-c-61_96_98.html?sort=6a&page=1
They're about 12pounds
Offline Zimmer64
    • Blog
Reply #8 on: January 19, 2013, 09:43:53 PM
Yes, take the 100K Ohm one.
Best
Mike
Offline earwaxxer
Reply #9 on: January 20, 2013, 04:54:14 AM
Yep - cant go wrong with the Alps....
Eric
Offline andrewuk
Reply #10 on: January 20, 2013, 05:05:23 AM
Its a funny old thing about volume controls or pots discussions rage, all over the galaxy, about the virtue of Alps over that make over some other one and although I have tried quite a lot the only thing I am sure about is that an Alps never has the problem outlined as the start of this thread. And, imo, that is the only virtue. I have never reliably heard a make of pot sound better than any other cheapie, or indeed the sort of 24 stage switches that have a couple of dozen surface mount resistors or indeed Dale's the like of which are lovely and cheap on eBay from Hongkers. Transformer based volume controls are in another league entirely but not without their problems i.e. mismatched impedance.
