Voltage problems
guf · 7823
Offline guf
on: January 20, 2013, 08:41:10 AM
Just finished my S.E.X amp. Not knowing anything about amp building I'm amazed that following instructions and soldering parts can produce sound.  I did have a few problems.
Resistance checks were with in range besides
A6   8.16
B6   1.18
Voltage had a few more issues
9 and 19     20 and 20
A1 and B1  20 and 25
A5 and B5  215 and 82
A6            9.4
C2           2.3
C5           2.5
I checked for obvious flaws and cant find anything. Thoughts or suggestions? My kit came with 2 different style of tubes but switching them did not make a difference.
thanks
guf
Reply #1 on: January 20, 2013, 09:20:47 AM
Start with C2 and C5, double check the orientation of those diodes, and the connections between the diodes and the terminal strip and transformer.
Having this voltage at 2.5V will throw the rest of the circuit out of whack.  Do the tubes glow?
Offline guf
Reply #2 on: January 20, 2013, 09:53:45 AM
yes they glow. and it even produces sound, good sound, just not great. it distorts at higher volume. the right channel (a side) is slightly quieter. thanks for your reply.
Reply #3 on: January 20, 2013, 10:20:50 AM
A6 has a resistor to ground that should be 1270 ohms, which is 1.27K ohms. There is an 8.2K resistor in the power supply, which is closer to what you measured - perhaps the resistors were swapped accidentally?
Offline guf
Reply #4 on: January 20, 2013, 10:36:50 AM
I'm suspecting the problem is something like this. the picture shows them being identical. the 8.2 k and the 1.27 look identical? trying to figure out which is which. can i test them by placing the meter probes on each side and noting the number?
Offline porcupunctis
  • 0D3
Reply #5 on: January 20, 2013, 10:46:28 AM
Yes.  You can test resistors just as you described.  Keep your body out of the circuit (do not hold the leads with your fingers) and you will get an accurate read.
I check every resistor before soldering.
Randall Massey
Teacher of Mathematics
Offline guf
Reply #6 on: January 20, 2013, 10:55:52 AM
also i should mention i was going off the old instruction guide and the switched to the new around paged 32. could i have some earlier discrepancies causing problem switching for old to new manual?
Reply #7 on: January 20, 2013, 02:08:03 PM
Well, both resistors are installed at about the same time. Look at the new manual, bottom of page 33 - the resistors look very similar, and are near each other and parallel. The 8.2K resistors are installed on p.32, the 1.27K on page 33.
Offline earwaxxer
Reply #8 on: January 20, 2013, 02:35:14 PM
True - measure twice - cut once. Good rule to live by.
Eric
Offline guf
Reply #9 on: January 20, 2013, 06:54:47 PM
Measuring the 4 light blue resistors from the bottom of page 33, None of them measure 1.27k. I did figure out that i had 2 of the 8.2 's on the A side. I changed them and my A6 value went down to 130, closer but off  and the other values are still too.  The Amp does perform well. The right side is a bit quieter but over all it's working great. Is it possible to have voltages so off and still get good sound?
Reply #10 on: January 20, 2013, 07:28:40 PM
I'd repost any voltages that don't match (recheck them all).
Reply #11 on: January 21, 2013, 03:16:42 AM
Guf,
You need only post the voltages or resistances that are greater than 15% off, plus or minus.  It will help the posters if you post your reading and the expected as well.  That keeps us from flipping back and fourth in the manual.
Offline guf
Reply #12 on: January 21, 2013, 06:34:58 AM
thanks for the replies and here is the updated data that is still off
Resistance
A6   3.2       should be   1.27
A2,B2   0    should be varying
Voltage
9 and 19     20 and 20 fluctuating  should be close to 0
A1 and B1  20 and 25 fluctuating  should be close to 0
A5            131               should be 75
A6            5                       should be 2.5
C2           2.3                 should be 3.15
C5           2.5            should be 3.15
« Last Edit: January 21, 2013, 06:37:27 AM by guf »
Offline guf
Reply #13 on: January 21, 2013, 07:11:00 PM
Replaced a few resistors and re soldering got my resistance in range.
Some my voltage problems revolved around the 220 ohm 1/4w carbon composition resistors. I got one side good and solved the A1 to 9 problem, then overheated the B1 to 19. I'm hoping i can replace those from my local store in the morning.
Still struggling with the C2 and C5 i'm getting a reading of 2.3 instead of 3.5. i was thinking of replacing the .1 wirewound resistor. could that be a problem?
Reply #14 on: January 21, 2013, 07:12:52 PM
What's the AC voltage between the power transformer terminals 4 and 5?
