Help in confirming wiring fornew slagel autoformer
Nutube · 4407
Offline Nutube
  • AudioAddicted-RefuseRehab
on: January 25, 2013, 05:06:38 PM
Hi all now that I am waiting for my FP3 manual any time now
I finally figured a way to install the pair of slagel avc physically on to the FP3. I entails some cutting of circuit  board and wood work on the FP3. I am leaving the selector original.
The Slagel is a coarse/ fine unit with both volume control per channel mounted on a circuit board.
There  are 3 points to solder  on the board GND, IN, and OUT.
Before wiring I thought to get help and confirmtion
My  take  is the OUT of the Slagel goes to Terminal 17 (?) through a resistor an on to pin 2  of the 12AU7.
There is a black ground  wire on  left most terminal T 16  which connects to a resistor and then to T11 which is one black leg of the auricap ( looking from the tube side with transformer in the rear) I think that wire goes to Slagel GND
The original selector has a foil shielded Black wire  with a red and black wire connected A and red to D of selector
My guess is that the black goes to Slagel GND so does the T- 16 black wire
The red wire goes from  D (selector)  to IN (of Slagel)
I will post before and after pics following this post as a reply
FP 1,2,3, Seduction, 45, Paramount 300B, Paraglow2A3; Dehavilland 845, Eico pp 805,Adcom 555 mono, Sota star saphire ugraded Nova motor & bearings,  Et 2.5 carbon wand on Shelter 901, Koetsu rosewood Sig., on magnesium wand, grado sumiko etc. Custom Edgarhorn with Seismic sub
Offline matthewmckay
Reply #1 on: January 26, 2013, 07:39:17 AM
... can't help you with the connections, but kudos to you for fitting those in there.
Offline Nutube
Reply #2 on: January 26, 2013, 11:38:06 AM
thanks mathew mckay
Took me awhile just studying it....... taking  a pair of thin snips to the circuit board corners was for me akin to bungie jumping. ( I dont do roller coaster either)
the dry fit and dremel grinding was most of it .
« Last Edit: January 30, 2013, 10:08:28 AM by Nutube »
