Electronics repair, or, fix what the factory missed
willspeed · 1881
Offline willspeed
  • Tropically Twisted
on: January 31, 2013, 07:42:51 AM
I ran into an interesting case a few days ago, I was wondering how many of you have run into the same deal.
A good friend of mine that I play guitar with occasionally called me because his 1-year-old Marshall AS100D had the second channel cut in and out, would die completely when he hit the phase switch, etc., etc. Of course, this is 3 days before a gig.
I guessed that maybe either there was a bad solder joint somewhere, or an intermittent ground. Now, this is a solid state amp, with 3 different boards. This channel lives in the lower front board along with the mic channel and the aux inputs. So, I go ahead, go to his place, take the amp apart, pull the board, and the solder joints look good, but there seems to be some kind of muck between a bunch of the switch contacts. Now, how did muck get to the BOTTOM of a circuit board, inside a closed enclosure? I assume that it must have been flux that wasn't properly cleaned off the board when it was manufactured - who knows why it took a year's worth of use to show up (heat made it flow?).
Contact cleaner, a fine brush, and ten minutes later - voila.. brand new amp. 3 cents worth of cleaner took care a huge bill for fixing an amp - crazy.
Small details that make a $700 amp a waste of space.  ::)
Will G.
S.E.X. w/C4S driving SEXy speakers
Seduction w/C4S
Quickie 1.1/ PJCCS
Rega Planar 2 / R200 Tonearm / Ortofon 2M Red / RB250 Tonearm / Ortofon 2M Blue
Tode / Taylor 110 / Taylor 214ce / 94 Tele Tex-Mex Special / Home-hacked Squire Strat / 86 Guild F46NT / Which one next?
