Need transformer help, please.
viridian · 17985
Offline viridian
Reply #15 on: May 27, 2013, 09:53:00 AM
PB, and right you are! D1 is at 6.25V and D2 is .52 millivolts.
Reply #16 on: May 28, 2013, 06:18:10 AM
What are the voltages at the "O" pads on each side of the center C4S board with no wires attached to those pads?
Offline viridian
Reply #17 on: June 15, 2013, 11:31:22 AM
PB, sorry for the delay; a little family issue. On the good side at the "O" terminal 231V DC. On the bad side, the voltmeter seems to just hunt but doesn't lock on at any voltage.
Reply #18 on: June 15, 2013, 11:32:10 AM
Do you have a stable voltage at both the "I" pins on that center PC board?
Offline viridian
Reply #19 on: June 15, 2013, 11:56:47 AM
PB, wow, you're Johnny on the spot. Yes, with the wires still disconnected from the "O" pads, I am getting 231V DC on both "I" pads.
Thanks again, Marty.
Reply #20 on: June 15, 2013, 07:35:58 PM
Try heating up the middle leg on the MJE350 that feeds the "O" pad that's problematic.
Otherwise, I'd see about getting a replacement PC board for that center position.
Offline viridian
Reply #21 on: June 16, 2013, 07:11:26 AM
PB, agreed it's time to start anew and populate a new board. I wonder what the original builder has in store for me after that........
Thanks again,
Marty
