Stereomour PA Conversion with upgrades complete!!!
balancedtriode · 3989
Offline balancedtriode
on: February 06, 2013, 12:04:33 PM
This sounds better than my system has ever sounded its probably the best I have ever heard!!!
upgrades include
tantalum resistors, power supply chokes , Mundorf film cathode bypass caps, bypassed psu caps. silver and OCC wire in select places new Mundorf caps signal caps. Shinkoh tantalum active load R1 Cardas gold connectors, Teflon tube sockets, gold IEC connector, military Hum pots, black walnut base, gold plated switch contacts, and a green neon pilot light.
you guys Rock I am listening to "Arthur" right now by the kinks
I am gonna be listening to music for hours!!!!
Its a great circuit !!!! totally worth the upgrades, Pics soon!!!!
Thorens TD-160 Custom(rebuilt by me) with SME 3009 arm
Bottlehead Seduction
Extended Foreplay-III (build underway)
Stereomour Power Amp conversion (Heavily Modded)
Klipsch Cornwalls' with Vertical Horns
Reply #1 on: February 06, 2013, 01:53:49 PM
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FFor%2520Posts%2520Private%2Fttiwwp.gif&hash=0e1ff14f92d482dce3204b6c713c79095fc4a395)
At the least, put some in the Gallery.
« Last Edit: February 08, 2013, 09:07:42 AM by Grainger49 »
Reply #2 on: February 07, 2013, 10:10:56 AM
here's a taste, waiting on a family member to return my good camera to take more photos and some under the hood shots,
I must say, this circuit Has been worth every upgrade, I used to be into High wattage solid state...(not the cheap kind either) and IMHO Low wattage SET amps, (specifically BH)with proper speakers  blows them out of the water!!!!!!
Reply #3 on: February 07, 2013, 11:45:07 AM
Coltrane,
Nice going!  I also can appreciate this as yet another data point in favor of the idea that better parts can and do make an audible difference.
Now you have to get that FP III going :-).
Offline saildoctor
Reply #4 on: February 07, 2013, 05:37:29 PM
I'm a little jealous of the glowing-ness coming from those mesh plate 2a3's!
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
Reply #5 on: February 08, 2013, 05:50:52 AM
Ah, the didn't mention the EmMLs :-).
Coltrane, if you could, when you have a minute, can you explain to me where and how you mounted the ps chokes?
Jim
Reply #6 on: February 09, 2013, 04:03:10 AM
First, by PA I meant power amp , not the more commonly used meaning Public address amp.
Secondly, the tubes are ceramic based Sophia Electrics the center tube is a psvane with a cooler/damper .
As for the power supply chokes I removed the power supply resistors put in two leads on each side with gold plated-solid copper male High voltage rated connectors. Then I put inline female connectors of the same type on the leads of the chokes. Then mounted them side ways on the inside of the walnut base, (this way I can remove the top plate by disconnecting the chokes). they are pretty close to the O.P.Ts but there is no audible hum. The amount of hum is even below what my gear can measure... except when I turn on the over head light(damn old house wiring) then there is a slight hum. I do however like listening to music with the lights off anyways so its not that big of a deal.
 I am in heaven... and it will even be better when the EFP-III is done!!!!!  :D
Reply #7 on: February 09, 2013, 05:45:16 AM
Hi Coltrane,
That's exactly what I was going to do with the chokes -- use connectors and mount them to the iside of the box.  I was mostly interested in where inside the box you mounted them so they ddidn't pick up or induce any hum, so thanks for that.
Good stuff and glad to hear that you're enjoying the amp so much.
Happy listening...
Reply #8 on: February 09, 2013, 07:34:22 AM
in my case no audible Hum, I can't vouch for in how it will work in your system, but there is no audible hum in my setup, listening to my Stereo copy of "A Whiter Shade of Pale" and all I can say is wow... I have had this record for years and its been a bit overplayed, yet it sounds better than it did when I unwrapped it years ago...
