chatham 2399
oldvstar · 5991
Offline oldvstar
on: February 12, 2013, 05:35:00 AM
I ordered what was supposed to be a Tung Sol 5998 last week, the box arrived yesterday and what I pulled out is a Chatham 2399. I spend a bit of time searching for information on this tube and what little I did find seems to indicate that the 2399 is like a 5998 but a little different. Can anyone here clarify just what this tube is? It definitely is not exactly the same as a 5998, to quote from a posting on Head-fi.org,
"There really are a number of differences.  Most easily appreciated is the presence of a 3rd spacer tab holding the top mica against the glass, probably to improve on microphonics.  There is an additional coating of some kind on the plates that was sprayed on after the micas were fixed in place, because you can see where the overspray, blocked by the plates, forms a cross on the bottom of the mica.  There is also an additional coating or jacket on many wires which are normally bare in the 5998 and 6AS7G.  Most obvious would be the copper grid posts and grid wires in place of the normal steel ones.  It looks like the pins have been tinned for some reason as well..."
I did a visual comparison, well as good as I could comparing what I had in my hand with pictures of a 5998 I found online and I verified the statement I quoted. I'm leaning towards keeping it because the one thing most could agree on is that it is a good sounding tube. But, does it sound as good as a 5998, and is it worth the same money I paid for a 5998?
On a different topic, I just finished installing the speedball upgrade and it was hard to imagine the Crack sounding better than it does in stock form, but the speedball is a killer upgrade. I am totally amazed at how great it sounds in my Beyer DT990's. Great job Doc and all of the others at Bottlehead.
Terry
Crack/Speedball, Beyerdynamic DT990 Pro 250, Sennheiser HD6xx, Wiim pro plus
Offline adamct
  • Maxxximum CAPacity Crack
Reply #1 on: February 12, 2013, 09:39:03 AM
I assume you ordered yours from vacuumtubes.net.
All of the 5998s were manufactured by Tung-Sol, regardless of what name appears on the tube. I believe this is true even for versions numbered 2399 - it was just that different manufacturers rebadged the Tung-Sol tubes with different numbers.
The differences in structure/manufacturing are probably just due to the tubes being produced at different times/years, when subtle changes in structure were made by Tung-Sol over the life of the product. I would expect the sound to be identical. I have several Tung-Sol 5998s and Chatham 2399s and haven't noticed any material differences.
Best regards,
Adam
Offline oldvstar
Reply #2 on: February 13, 2013, 08:30:22 AM
Great, thanks for the reply Adam, and yes, I did buy this from vacuumtubes.net. I guess what it comes down to is that I'm loving the sound of my Crack+speedball with this tube in it. I'll give this some time to burn in and then I'll try the CBS/Hytron 5814 that I bought with the 2399.
Terry
Reply #3 on: February 15, 2013, 06:18:40 AM
If that CBS Hytron is the mid-50s red label variety, you should be very happy -- very nice, well balance tube, but getting fairly hard to find.
Offline oldvstar
Reply #4 on: February 18, 2013, 02:12:16 PM
I had to wait until I got home to look but the 5814 I have is a red label, gives me something to look forward to once my ears clear up from the cold I have. There are advantages to having bad hearing in one ear, except my wife caught on really fast.   ;)
Terry
