Side A does't work... help !? SOLVED :) THANKS PAUL FOR THE FAST GUIDING
zs1962 · 2854
Offline zs1962
Hi,
Just built the new quickie and the A side doesn't work (with both inputs, both tubes...).
Checked all I could and...
I measure on A 1/7 1.4v while on B1/7 3v.
Any ideas for what might be the problem ?
(I switched the caps (the 150MF), checked the resistors...
Ze'ev
« Last Edit: February 17, 2013, 12:26:32 AM by zs1962 »
Reply #1 on: February 16, 2013, 04:34:08 PM
I'm guessing either A2/6 is zero (no voltage from the 36-v array) or a bad connection at A5 so no filament current is flowing. Or of course a failed tube - swap tubes to check that!
Offline zs1962
Reply #2 on: February 16, 2013, 09:09:06 PM
PAUL THANKS !!!!!!!!!!!!!!!!
Woke up this morning (we are 10h behind you); read your lines that focused me precisely to where I also thought the problem must be; measured carefully the connectivity path to A4 and... yep ! the resistor connection to Terminal 1U was COLD... soldered it right and MUSIC IS PLAYING !
This is my fourth project. I built the Stereomour and now the Quickie and the Foreplay3 and Tode are still waiting. The Forum experience and your support are just superb !!!
Have a great weekend,
Ze'ev
« Last Edit: February 17, 2013, 12:24:39 AM by zs1962 »
