Other Gear
Speakers
Cain and Cain Abby
Cain and Cain Abby
tsingle999
18744
tsingle999
Sr. Member
We are all here because we are not all there.
Re: Cain and Cain Abby
Reply #15 on:
July 09, 2013, 04:37:49 PM
I got the esr's back from planet 10!
The magnets dont fit the abby holes. There a smidge too small... What would be the best way to open these up? I have a rasp - that would do it i think?
Bottlehead Stat headphone amp
4krow
Guest
Reply #16 on:
July 10, 2013, 12:15:10 PM
Don't know if you own a Dremel, but that might be a good way to do it, using a sanding drum. If not that a sanding drum on the end of a drill might also work.
tsingle999
Sr. Member
Reply #17 on:
July 10, 2013, 12:44:26 PM
Thanks! I will try the dremel!
4krow
Guest
Reply #18 on:
July 10, 2013, 02:22:07 PM
You will find that the Dremel has more control, and leaves a much finer finish than a rasp. Of course, we all want to see photos of the finished product. C&C are great looking products.
tsingle999
Sr. Member
Reply #19 on:
January 10, 2014, 06:28:35 PM
I finally got one in! I used a drill bit that spins and is sort of like a round cheese grater. It was a lot of work though and hard to keep it uniformly circular. Boy i like both drivers. The new model is really powerful bass. The esr is very refined and more detailed.
Other Gear
Speakers
Cain and Cain Abby
