another Voltage reading problem
stingers96 · 3374
Offline stingers96
on: February 20, 2013, 05:09:19 PM
I am building my first kit and everything as going well until i installed the power supply PC board and connected it to the transformer. the voltage was correct when i connected the meter to the 270K ohm resistor and th 270K ohm 5W wire wound resistor (got a reading of 380V) When i unplugged it from the wall it took several minutes for the voltage to bleed off.  I figure thats OK.  But when i plugged it back in and tested the 6.3vDC + pad on the board i got no reading.  I checked all wire solders and they are all sound connections.
I am at a loss and dont know what to do.  Please help so I can continue my build.
Thanks in advance
Ryan
« Last Edit: February 20, 2013, 05:21:52 PM by stingers96 »
Offline vetmed
Reply #1 on: February 20, 2013, 05:18:03 PM
Its unclear to me what stage of assembly you are at. I have built 6 or 7 Bottlehead kits and have always waited until assembly was finished to check ohms, never mind plugging something in before assembly is finished. If I have misunderstood please excuse me.
Robert Lees
Robert Lees
Offline stingers96
Reply #2 on: February 20, 2013, 05:19:41 PM
i am on page 44/45 (Power supply voltage test) where the manual instructs you to test the voltage
« Last Edit: February 20, 2013, 05:23:20 PM by stingers96 »
Reply #3 on: February 20, 2013, 05:26:30 PM
Rats, I lost my post. Try again:
1) Check the AC voltage between the PC board terminals marked T4 and T5. This is the transformer input to the heater supply; it should be about 9 volts AC.
2) Check the DC voltage from ground to the striped end of the two diodes at the forward end, near the heat sink and the +/-6.3v terminals. It should be around +10 volts DC.
3) If that doesn't disclose a problem, then measure the voltages at each of the three pins of the regulator chip. Be careful - you don't want to short then to each other, which is way easy to do!
Offline stingers96
Reply #4 on: February 25, 2013, 05:53:21 AM
Thanks for the quick reply, unfortunately i was drawn away from my build for a few days. After close inspection (with a magnifying glass) i noticed 2 of the 1N5829 Schottky rectifiers were in backwards.  the silver line was almost worn off completely on both .  After removal and re-installation all voltages tested exactly as expected.   Hopefully i didn't blow anything as a result of my mistake.
Ryan
