Sr45 transformers
tsingle999 · 3873
Offline tsingle999
on: February 23, 2013, 04:43:34 PM
Somewhere i stumbled on a post about different transformers for the sr45. PJ mentioned the robin hoods. Would that be worth trying? I currently have 2004jrs. Would there be any other changes to make to it? How about the 2004sr? Thanks, Taran
Bottlehead Stat headphone amp
Reply #1 on: February 23, 2013, 05:17:26 PM
The Robin Hood is much different in size and impedance, hence a re-design - mechanical and electrical - would be called for to obtain optimal results. And frankly, the TFA-2004Jr is a superior design IMHO.
The TFA-2004 Senior could be a step up - hard to believe since by the numbers the Junior is plenty adequate for a 45 (it can handle a 300B quite well ...) and the Junior should have slightly better treble. For a 45, there is not much point in getting anything less than the full-nickel core though. But having heard a couple John Tucker 45 amps with nickel-core TFA-2004s, I am confident there is an improvement. It does fit the chassis, though you would have to drill new mounting holes and a grommeted hole for the leads.
Offline tsingle999
Reply #2 on: February 23, 2013, 05:54:01 PM
Ok i will try that:) i have nickel sr's. (i'm still trying to find an amp for my fs100 plate chokes -that might be overkill!)thanks Paul!
Reply #3 on: February 24, 2013, 04:11:54 AM
Taran,
Well, at least you'll have plenty of magnetic headroom :-).  Big PF caps though.
« Last Edit: February 24, 2013, 04:38:30 AM by Jim R. »
Offline xcortes
Reply #4 on: February 24, 2013, 04:32:03 AM
I'm building a set with exo 050s full nickel. One has already all the hardware installed. Both boards are populated and soldered. I hope to finish them in the next couple of days (alternating with the BeePre and with the -finally- setting up of my Eurodyns).
I'm saving the Jrs Co for the 300Bs to go with the WE.
Xavier Cortes
