quickie 1.1 PJCCS typo?
bugeyes · 2725
Offline bugeyes
on: March 01, 2013, 06:42:07 AM
Was wondering if the following are typos in the manual;
1.connect OA to B6...., wouldn't it be OB to B6 since OA is already connected to A2 on the A side of the circuit.
2.B6 is already connected to 6L...., if the circuit is symmetrical, the A side has OA going to A2 which is an unoccupied pin on the tube socket. Seems to reason OB should go to B2, is this correct ???
 If I am reading the schematic right, seems the pins 2 and 6 are basically the same connection?
« Last Edit: March 01, 2013, 08:57:49 AM by bugeyes »
Offline bugeyes
Reply #1 on: March 01, 2013, 11:51:53 AM
I went ahead and just used the schematic and it fired up just fine. I would suggest that maybe you would want to clarify the previous points ;D
Reply #2 on: March 01, 2013, 05:54:14 PM
It should be OB to B6, we'll get that corrected.
