how not to build your bee pre
xcortes · 33927
Offline STURMJ
Reply #15 on: March 08, 2013, 08:08:46 AM
So the big question is....Now that you have done it, was working with the coax worth it? ( I have some, and have a Prebee coming) I have some silver wire, that I would normally use to wire inputs (shielded), But I would consider the coax.
Offline xcortes
Reply #16 on: March 08, 2013, 09:48:54 AM
Quote
We'll never know, I gues. I'm sure the Pre would sound fine with either cable. What I do know is that replacing CAT5 interconnects with 85259 ones was a move in the right direction. The CAT5 ones didn't sound bad, I lived with them for many years. And the change wasn't huge. The effect was positive but small. In the BeePre case the lengths are so short that the effect is probably even less. It took me maybe a couple of extra hours to wire the inputs. Hopefully this weekend I'll do the outputs. Worth it? Hard to measure.
Xavier Cortes
Reply #17 on: March 08, 2013, 11:09:09 AM
Xavier,
I haven't been on line much because I'm contracting for K-C in Loudon TN.
The Belden 89259 is a newer version of 9259 I have been using for 20 years.  Great stuff but a booger to work with.  It is the best RG-59 I have ever found.  I have a number of cables made from it.  Low capacitance, stranded center conductor, easy to bend (compared with a solid conductor).  Not to mention it really sounds good, great soundstage.
I see that you are taking your time and doing it your way.
Congratulations!
Offline Maxwell_E
Reply #18 on: March 08, 2013, 12:23:48 PM
That coax looks intriguing. It seems like a nice thing to have around for interconnects and projects like this. I found it on Markertek and Mouser and the smallest I'm finding is a 500 foot box. Is there anywhere that would have it in smaller packages or even by the foot?
Max Tomlinson
SEX amp, Tode guitar amp
Reply #19 on: March 08, 2013, 12:31:35 PM
Maxwell,
Right in your own backyard:
http://www.rawcable.com
A division of bluejeanscables.com, and much cheaper than Mouser, etc.  and yes, you can buy by the foot.
Offline xcortes
Reply #20 on: March 10, 2013, 10:32:16 AM
The 157M chokes fit perfectly!
Xavier Cortes
Offline Maxwell_E
Reply #21 on: March 10, 2013, 01:32:03 PM
Thanks Jim. I should have thought to just call Blue Jean's and ask nicely.
Max Tomlinson
Offline johnsonad
Reply #22 on: March 10, 2013, 03:27:20 PM
Interesting! After the noise in my Eros with the choke under the hood I'm apprehensive of putting them that close to signal wire under chassis. Please keep us posted if you end up with noise.  This is the one mod I'm going to hold off on.
Offline caffeinator
Reply #23 on: March 11, 2013, 06:02:31 AM
Hi Xavier,
Will you have to do anything to the base to accommodate the 157M's under the chassis plate?  From the photo, I can't tell if the chokes go that far outboard.
thanks!
Offline xcortes
Reply #24 on: March 17, 2013, 07:13:21 PM
Hammond chokes in place. They fit and there's no need to modify the base.
BeeQuiet switches also in place.
« Last Edit: March 18, 2013, 07:57:35 AM by xcortes »
Xavier Cortes
Offline caffeinator
Reply #25 on: March 18, 2013, 09:12:29 AM
Hi Xavier,
Awesome - thanks for the follow-up and the picture!
Best,
david
Offline xcortes
Reply #26 on: March 30, 2013, 05:35:59 AM
One output channel wiring. A single 89259 feeds all four outputs. No piggibacking here!
Xavier Cortes
Reply #27 on: March 30, 2013, 05:45:11 AM
I have to ask, since it is dual mono, has anyone been tempted to put in two IEC connectors so you can use 2 Botthlehead power cords?
Reply #28 on: March 30, 2013, 06:33:40 AM
I think it might sound better with four runs per channel, you should give it a shot!
(Just joking)
Offline xcortes
Reply #29 on: March 30, 2013, 06:42:27 AM
Grainger, not me. I haven't even tried the bh power cords yet.
Paul, look at this other pic showing the output wiring of both channels.
Done with the PITA input and output wiring. Next is the beeQuiet and then the actual preamp power and signal circuits. I'm getting there!
Xavier Cortes
