quickie volume control
underdawg · 2798
Offline underdawg
on: March 03, 2013, 07:27:16 AM
I took measurements of stock volume control. I have a noble ap 25 pot but it has 4 posts per side. I I assume the stock volume control center pin is the reference based on resistance readings. I am going to wire the noble based on resistance readings compared to the stock, I assume this would be ok?
Reply #1 on: March 03, 2013, 08:15:57 AM
On the pot, two of the lugs shouldn't change when you rotate, those will be the input and the ground (hooked up essentially in the same manner as the stock pot.
On the 4-lug pots I have seen, there will be one lug between these two, and that will be equivalent to the center lug on the original pot, then the other lug will be the loudness tap.
If the two lugs that don't change are the two outermost lugs, then you'll have to do some measuring and comparing to determine which is correct.
In any case, the risks are exceptionally minimal here with this tweaking.
