got my quickie built , checks fail
underdawg · 2736
Offline underdawg
on: March 03, 2013, 11:55:22 AM
The circuits cehck as follows:
Everything in resitance is good except a1 and b1 read open referenced to ground
Everything in voltage checks is good except rotary b reads 0 volts
is the problem my noble volume control?
Thanks for the assistance
Reply #1 on: March 03, 2013, 01:23:55 PM
If A1/B1 are open to ground, but A7/B7 are not, then there is certainly an issue, as those should be tied together.
If the voltages at 1 and 5 are close to the specification, I'd suspect a measuring issue at the other locations
Offline underdawg
Reply #2 on: March 04, 2013, 03:32:20 AM
turns out I got the termianl strip numbered wrong had to undo will rewire today and let you know the new measurements.
« Last Edit: March 04, 2013, 10:26:50 AM by underdawg »
