Quickie Gain
underdawg · 9382
Offline underdawg
Reply #15 on: March 10, 2013, 06:52:01 AM
ok I am sad. Thank you paul the stock volume control works alot better than the noble.The only isssue I have left is switching between sources causes a loud pop or bump, any ideas? Still have not installed the pcjj yet as I am trying to get the original working perfectly.
Reply #16 on: March 10, 2013, 08:08:37 AM
The bump comes from the rotary switch, and will quiet down a bit after some use.
Sorry that the Noble pot wasn't up to snuff, but this is why we always advocate that you build the kit stock first.
Offline underdawg
Reply #17 on: March 10, 2013, 08:35:37 AM
fair enough ill keep on eye on the bump, should i wait for it to meelow out or install the pcjj now?
Reply #18 on: March 10, 2013, 11:23:34 AM
Something that is seldom discussed in audio circles but well known in the recording industry is the "exercising" of pots and rotary switches. Every once in while it is a good idea to run pots and rotary switches through their full range a few times to clear off any crud that might have built up. Exercising that switch will help to burnish the contacts and quiet it down a bit.
4krow
Reply #19 on: March 10, 2013, 12:23:48 PM
Doc, would that apply to  the plastic strip pots as well as to the carbon track ones? And do you think that a sealed pot would require this as well?
Reply #20 on: March 10, 2013, 12:50:33 PM
I can't think of any reason not to do it to any pot. Sealed pots should, in theory, not need it (or at least need exercise less often). Why not do it anyway?
I have just installed a couple of CTS conductive plastic sealed pots (283 series) in my new guitar. Small, quite nice feel and very quiet. Interesting to note the rated lifetime for the similar 282 series is 2 million cycles. I'm guessing 283 is log and 282 is linear, but not sure about that.
Offline adamct
  • Maxxximum CAPacity Crack
Reply #21 on: April 22, 2013, 05:49:30 AM
If my DAC puts out a 2V signal, and I turn the Quickie up all the way, what will the signal to my amp be?
Best regards,
Adam
Reply #22 on: April 22, 2013, 07:19:48 AM
The answer to this question depends on a few other parameters, and they are (I'll probably miss one or two here!)
1.  The load seen by the Quickie (input impedance of your power amp(s).
2.  PJCCS, Choke, or Resistor plate load
3.  Freshness of batteries
4.  How much THD is acceptable?
Under ideal circumstances (PJCCS/no load), I think you'd get maybe 10dB of gain out of the Quickie, which would get you 6V out.  This seems tight in terms of compliance within the PJCCS, but I would want to test it myself to see what happens.  With a stock Quickie, that would drop to ~4V.  With decreasing load impedance, the output impedance of the Quickie will become a factor, and the voltage present at the input of your amplifier will decrease more.
The good news is, you can play a 60Hz tone through your DAC and measure the AC voltage out with your meter.  This won't tell you much about distortion, but it's a start!
Having made too many assumptions, I just performed the measurements. I can get 11dB of gain with 0.7V in and 1.5% THD with the PJCCS and no load.  This drops to an even 1% at 8dB of gain.  Unfortunately, my testing setup won't generate 2V of signal, and our low-noise/low-THD testing amps aren't finished yet, so that's all I can report.
Offline adamct
Reply #23 on: April 22, 2013, 08:49:33 AM
Thanks, Paul. Much appreciated. I can't find input impedance specs. for my headphone amplifier. I will be using the Quickie with the PJCCS.
But you're already answered by question, so I'm all set. Thanks!
Best,
Adam
