Quickie Gain
underdawg · 8420
Offline underdawg
on: March 06, 2013, 02:49:44 AM
NOw that my preamp is up and running the gain is way to much. I can only get 2 stepped positions out of noble volume control, which is 100k. What is the best solution to get the gain down to gain more volume control?
Reply #1 on: March 06, 2013, 06:06:35 AM
Add two 100K resistors between rotary switch terminals A and B and the input of the potentiometer.  Do you have a link to the Noble control you bought?  It may be likely that 100K isn't enough.
You can also pad the inputs of your amplifier, which is the best way to go IMO, but often the least accepted.
Offline Wanderer
Reply #2 on: March 06, 2013, 06:11:51 AM
............I can only get 2 stepped positions out of noble volume control, which is 100k. What is the best solution to get the gain down to gain more volume control?........
Are you sure the control you have is logarithmic, "audio", taper not a linear taper?
Kevin R-M
Offline underdawg
Reply #3 on: March 06, 2013, 06:14:23 AM
sorry dont have a link, the paper with the noble is a small manual but it contains just the electrical specs and all the measuremnents of physical construction. I will add the resistors to the rotary switch a&b. If not enough volume movement gain then ill add to the potetiometer inputs. Thank you for the idea's. Maybe I will try some pads on the amps also first , check the sound, I assume just a resistor - what value to pad the amp input?
Offline underdawg
Reply #4 on: March 06, 2013, 06:15:10 AM
no idea on that one, the manual state its is a noble audio volume control.
Reply #5 on: March 06, 2013, 06:19:09 AM
Try this in the amplifier:
-----input---->
                  100k
                     |---------->output
                   10K
----ground-----|
There may already be a resistor there, if it's over 100K, you can just leave it there if you want to, if this is a solid state amp and that resistance is pretty low, then I would advise leaving it in place and using it as your lower resistor in the picture above.
Offline underdawg
Reply #6 on: March 06, 2013, 07:07:02 AM
My amps are Odyssey Stratos Monoblocks regular edition at the moment- Klaus is sending me ann upgrade kit for them which I will do and then rebias the amps., no zobels or anything else on speaker terminals, Ill have to check the boards more closely. Ill try that circuit you gave me. I have not installed the pcjj upgrade yet to the quickie , I really enjoy the sound now except for the over whelming gain.
Reply #7 on: March 06, 2013, 08:43:47 AM
Well, the Quickie is a very, very low gain preamp (around 7dB), the Odyssey Candela that could be a companion product to your amplifier has twice the gain by comparison.
It looks like your amps have ~22K input impedance, but no specified sensitivity.  You can lift the wire leaving the center pin of each RCA jack on the back of the amp and add a 100K resistor to start (feel free to check with Klaus on this one).
A lot of the time the sensitivity issue can be the combination of pairing a sensitive amplifier with sensitive speakers, and in this instance I'd imagine your loudspeakers are well over 90dB efficient.
Offline underdawg
Reply #8 on: March 06, 2013, 01:40:22 PM
I tried the circuit above you gave me and it did work but it took to much gain away, 2 volume positions to 5 positions but then no more gain if I contined on the volume control-noble ap25, when plugged in direct its way to much gain from the quickie only 2 volume positions before blasting me out of the room literally, my hafler modified preamp solid state, my cary preamps which are tube work fine. My musical design tube also worked fine in this system. I am not sure maybe I have something wrong in my circuit in the quickie? I did try diferent tubes which made a difference in the gain of the quickie also. My speakers are 90db Vmps Super tower R's I think, not the 7 footers but the 5 foot speakers in this system with 2x 15s, 1 12 and other drivers in each cabinet. I guess over the weekend ill try the quickie in my other system, cary cad 100s in triode mode, but speakers are 90db also cabbasse 8 inch woofers and tweeters.
Reply #9 on: March 06, 2013, 05:47:45 PM
Try installing the stock pot.
Offline earwaxxer
Reply #10 on: March 07, 2013, 03:15:32 AM
Sage advice from PB - built it stock first - get it to work - then mod away.
Eric
Offline underdawg
Reply #11 on: March 07, 2013, 03:55:00 AM
Ok  ill install the stock pot this weekend.
4krow
Reply #12 on: March 07, 2013, 04:07:02 AM
Dam Eric, I have to second that thought. My first 'Q' had all kinds of changes that I made to it and it held me up. I will be getting the new 'Q' today, and I promise to be a good boy this time.
Offline matthewmckay
Reply #13 on: March 07, 2013, 06:58:42 AM
Hey UnderDawg, I feel your pain... I had a very similar problem in my setup.  way, way too much gain...  PJ helped me with some calculations and I installed a voltage divider with some tantalum resistors at the amplifier input.
here is the thread about my issue/Paul's suggestions
http://www.bottlehead.com/smf/index.php/topic,2049.msg15833.html#msg15833
here is a voltage divider calculator
http://www.raltron.com/cust/tools/voltage_divider.asp
good luck
Offline underdawg
Reply #14 on: March 07, 2013, 01:31:45 PM
yes we tried that but it took to much gain away :)
