Paramont LED's
jeffj · 5719
Offline jeffj
on: March 13, 2013, 12:37:59 PM
Hello All
I am enjoying time spent with a soldering iron.  Can't wait to here the new paramount in my system.
One quick question.  Maybe I have too much smoke in my eyes but I only see four spots for LED's in the manual for each amp but my kit cam with 5 per amp (10 total) and 10 are listed on the packing slip.
Where does the fifth LED belong?
TIA
Jeff
Jeff
AR-XA
Squeezebox
Foreplay III
Paramounts
Klipsch Cornwall
Madisound BK-16
Offline pdxgrampa
Reply #1 on: March 13, 2013, 01:10:11 PM
Hi Jeff
Got 10 with mine also.2 are spares.
Greg
Music Hall 5.1SE,EROS. OPPO 980HD, Music Hall 25.3 Dac. BeePre/BeeQuiet. Paramount V1.1 300B,Orca Deluxe W/ Subs/SPA250s.Stereomour W/Orca Deluxe. Crack W/Speeball(2) .Beyerdynamic 990s.Crackheadphone.
Offline Paully
Reply #2 on: March 15, 2013, 05:57:28 AM
Maybe my memory is faulty, but don't you use four on the board and a fifth one for the tube socket depending on whether you are using a 300B or 2a3?  Should be there in the directions if so.
Offline ssssly
Reply #3 on: March 15, 2013, 06:54:42 AM
Pretty sure the extra two LEDs are there for when you wire one of the others backwards and fry it.
They aren't used anywhere else in the amp.
Unless you want to use them to replace a resistor someplace. But then you will just have extra resistors. Which doesn't really solve the extra parts problem.
Reply #4 on: March 15, 2013, 09:27:04 AM
It's just a hangover from the old, pre-soft start version of the amp.
Reply #5 on: March 15, 2013, 10:28:54 AM
Still, very kind to supply a couple of extras for the most often botched part in the kit.
Offline Paully
Reply #6 on: March 15, 2013, 02:05:40 PM
Ah!  Thanks for the clarification, I appreciate it.
Offline jeffj
Reply #7 on: March 17, 2013, 09:44:29 AM
Just finished the build.  Resistance and voltages checked out perfect. Now listening to music!
Thanks Doc and crew for another great kit!
Jeff
AR-XA
Squeezebox
Foreplay III
Paramounts
Klipsch Cornwall
Madisound BK-16
Offline jeffj
Reply #8 on: March 19, 2013, 06:24:10 PM
So I was listening in the dark this evening and went up close to look at the 300B's.  One of the tubes has blue glowing vertical streaks in the top half of the tube and the other tube does not.  Is this normal?
Also when I crank the volume the blue streaks start to pulse.  Which btw looks very cool up close.
TIA for any input.
P.S.  Really enjoying the sound. Hooked up the Madisound BK-16's tonight(although I prefer the Cornwalls)
What is the break in period for the amps/tubes?  I find they sound MUCH better after being turned on for a couple of hours.
Jeff
AR-XA
Squeezebox
Foreplay III
Paramounts
Klipsch Cornwall
Madisound BK-16
Reply #9 on: March 19, 2013, 06:25:05 PM
No. Usually both of them do.
Offline jeffj
Reply #10 on: March 20, 2013, 07:08:35 AM
Doc is this something I should be concerned about?
A build mistake on my part?
A problem with the tube itself?
Jeff
AR-XA
Squeezebox
Foreplay III
Paramounts
Klipsch Cornwall
Madisound BK-16
Offline Paully
Reply #11 on: March 20, 2013, 07:28:21 AM
Nah, its just some sort of gas in the tube that electrons are bouncing off of (or something like that).  Its just makes them look pretty!  It is part of the manufacturing process in some tubes, but not others.  Its natural for those tubes and means nothing.  Enjoy the music!
Reply #12 on: March 20, 2013, 08:47:46 AM
Yeah, my post was meant to imply don't worry, be happy.
