Front panel designer - crack template
kingsun · 18990
Offline kingsun
on: March 16, 2013, 05:26:47 AM
Hi,
I'd like to order a custom top plate. Does anyone have a standard template for the crack top plate that I can work from?
I just wanna make sure that the screw mounting holes are spaced correctly from the socket holes etc.
Thx
Offline kingsun
Reply #1 on: March 22, 2013, 09:29:10 AM
So, I went ahead and ordered a panel (template attached). It should arrive this week. Let's hope the measurements I made are correct.  :)
Offline galyons
  • Geary Lyons
Reply #2 on: March 22, 2013, 07:58:48 PM
Are you moving the IEC, RCA's, vol pot and jack to the rear?  don't see them on the FP design.
Cheers,
Geary
Offline kingsun
Reply #3 on: March 23, 2013, 01:01:46 AM
Yes rca to the rear right, iec to the left. Volume front right, headphone jack left and switch plus led front center. At least... that's the plan  8).
Only thing I forgot on the frontplate are the mounting holes for the speedbal!  ::)
Offline kingsun
Reply #4 on: March 26, 2013, 07:50:51 AM
Received my topplate and it is awesome! Also, it came with gummy bears!!!!!!  ;D
Offline galyons
  • Geary Lyons
Reply #5 on: March 26, 2013, 02:59:06 PM
Looks very nice. Did you have FP do a plate for the rest of the connectors/pot or will they be mounted in the wooden case?
Cheers,
Geary
Offline kingsun
Reply #6 on: April 06, 2013, 08:09:20 AM
Theye are mounted in the wooden base:
http://www.bottlehead.com/smf/index.php/topic,4104.msg37552.html#msg37552
So the template I uploaded has the correct measurements if anyone wants to use it, only thing missing are the Speedball and the ground mounting holes.
Offline SammyJ
Reply #7 on: January 05, 2015, 04:19:28 AM
Hey, quick question to the OP (sorry for the resurrection) -- who did you use to manufacture your custom top plate?
thanks,
S
Offline JamieMcC
Reply #8 on: January 05, 2015, 08:12:55 AM
Most probably the FP is short for Front Panel Express
http://www.frontpanelexpress.com/
Offline catfishstevens
Reply #9 on: May 11, 2015, 02:04:49 AM
Does anybody have a copy of the template he used?  The attachment isn't working for me and I'd be interested in this!  If there's an updated one with the Speedball that'd be even better.  Thanks!
Offline simondadiamond
Reply #10 on: May 18, 2015, 03:26:53 PM
I too am very curious about this. This is exactly what I'm looking for, did OP or
find anything?
Reply #11 on: May 19, 2015, 06:45:58 AM
I too am very curious about this. This is exactly what I'm looking for, did OP or  find anything?
There is someone's template in the second post in this thread.  We haven't ordered it, checked it, or tried it, so YMMV.
Reply #12 on: May 19, 2015, 05:55:32 PM
Thanks, the document seems corrupt though... :(
Reply #13 on: May 20, 2015, 01:59:33 PM
I sent Doc an email asking if he could provide me with FPE files after I posted in this thread, and he was (perfectly understandably) reluctant to send me proprietary information.
I got out my calibrated measurement equipment and measured it relatively carefully, then drew it in the FPE software.  I picked it up today and it is a nearly perfect match; I am very happy with the work that FPE did for $48.  I didn't get fancy, I just wanted a gold anodized finish to match with my ebony base.
I'll post it here if Doc is okay with that.  It sounds like PB would be okay with the file posted originally if it worked, but given his response to my email I'll defer to Doc.
In the event they don't want it posted, it isn't that hard to measure.  You already have most of the SAE hole sizes from the screws, just a few odds and ends after that.  Since it is less than 8.5x11 you can print it to scale in FPE on a regular printer and line that up with your original front panel to check yourself.
Reply #14 on: May 20, 2015, 07:54:59 PM
I would prefer that you do not post a file of a copy of our chassis panel on this forum.
