Music only playing through one ear
cayoung05 · 9812
Offline cayoung05
on: March 16, 2013, 08:17:35 PM
Hey everyone,
Just built my crack and all the resistance and voltage checks were fine. I fired the amp up, plugged in my RCA cables into my DAC and the crack, but I can only hear music through one ear. Does anyone know of any solutions to this problem? Thanks in advance
Reply #1 on: March 17, 2013, 06:09:49 AM
First make sure the headphone cable is plugged in all the way. Next swap the RCA cables to see if the dead channel follows the cable. Next, power off, power cord disconnected, measure resistance across from the center pin of each RCA jack to the ground tab with no cables plugged in and the volume knob all the way up. You want to be sure neither jack reads zero ohms. Also visually inspect to be sure that solder hasn't accidentally bridged from the center pin to the outer ring of the rca jack. do the same type of measurement at the headphone jack with the headphone cable unplugged. Measure resistance from the tip to sleeve and from ring to sleeve. Sleeve lugs are closest to the chassis, tip farthest from chassis. Each should be around 2.5k ohms.
Offline cayoung05
Reply #2 on: April 07, 2013, 09:10:10 PM
I've resoldered all the joints, and all the voltages and resistance checks seem fine, but i still cant hear anything in the right headphone. I noticed, like one of the others posters on this forum, that when I plug the headphone jack halfway, I can hear from both headphones. Could this have something to do with the tube(s)?
Reply #3 on: April 08, 2013, 04:57:25 AM
Hearing one channel on both headphones when partly inserted is simply the way stereo headphone jacks work. Did you do the checks I suggested along with the ones in the manual?
Offline cayoung05
Reply #4 on: April 12, 2013, 10:24:22 PM
Doc, thanks for the reply. My answers to your questions are below
check
I swapped the cables but now it seems that both channels don't work
neither jack reads 0 ohms, both have resistance
this might be a problem. The solder has overflowed from that center pin with the cable in it, down the outside sides of the pin, and into the inputs below. Could this be the problem?
both read around 2.4k - 2.5k ohms, so all good there
Reply #5 on: April 13, 2013, 07:00:38 AM
Yes, this is the problem. The "hot" of the signal from your cable is carried on the center conductor. The outer shell is at ground potential. If the center pin of the RCA jack is bridged to the outer shell you have shorted the signal to ground before it gets to the amp. Carefully reheat those RCA jacks just enough to get the solder bridge to open so the center pin and outer shell are not connected. Go easy, the insulator in between can melt if you hold the iron to the jack for a long period of time. Do this with the cables removed. Turn the volume knob up all the way and measure the resistance from the center pin to the ground tab on each of the RCA jack. It should not read 0 ohms, but rather more like 100K ohms.
Offline cayoung05
Reply #6 on: April 22, 2013, 08:48:21 PM
That did the trick! Now listening to some Beethoven in pure heaven. Thank you Doc and Eileen for your help, was a blast to make and even more to listen
Offline earwaxxer
Reply #7 on: April 23, 2013, 01:46:23 PM
I guess you got it solved.. I was thinking that you should check your connections in the corpus callosum. I had a short there the other day. Nothing that a good blow to the head and fifth of Gin couldnt fix. Not in that order though...
Eric
Offline cayoung05
Reply #8 on: April 28, 2013, 09:23:44 AM
Haha, I stopped checking my corpus callosum, that was damaged a long time ago and they told me it was beyond repair  :P .
So... Having the same problem again. Everything was working fine, then the right channel decides to cut out while I'm listening. I resoldered the right pin and it worked again for 10 minutes, then cut out again. I did all the checks above, and all the voltage/resistance checks seem fine. The solder from the center pin is not bridging to the outer ring either. Any other suggestions I should try?
Reply #9 on: April 28, 2013, 09:56:21 AM
Post voltages (once the right channel has cut out).
Offline cayoung05
Reply #10 on: April 28, 2013, 10:50:19 AM
Here's the resistances.
1. *
2. *
3. 0
4. *
5. *
6. 2.4K
7. 2.9K
8. 0
9. 2.9K
10. 2.4K
12. 0
13. *
14. 0
20. 0
22. 0
B3. 2.9K
B6. 2.9K
RCA jack:
Center pin: both start with a number but quickly Go down to 0
Headphone jack:
Top 2= 2.4K
Bottom = 0
Voltages
1. 88
2. 177
3. 0
4. 177
5. 88
6. 0
7. 111
8. 0
9. 110
10. 0
11. 0
12. 0
13. 177
14. 0
15. 199
20. 0
21. 222
A1. 88
A2. 0
A3. 1.5
A4. 0
A5. 0
A6. 88
A7. 0
A8. 1.5
A9. 0
B1. 88
B2. 178
B3. 111
B4. 88
B5. 178
B6. 110
B7. 0
B8. 0
Thanks for the help
Reply #11 on: April 28, 2013, 03:32:05 PM
Turn the volume knob all the way up, then remeasure the resistance between the center pins of the RCA jacks and ground.
Were those voltages taken when the right channel was out?
Offline cayoung05
Reply #12 on: April 28, 2013, 08:36:59 PM
Ground to left channel center pin = 6.8K
Ground to right channel center pin = 0
The voltages were taken with the right channel cut out
Reply #13 on: April 29, 2013, 03:32:42 AM
Those are resistances with the knob all the way up (it seems unlikely)?
Offline cayoung05
Reply #14 on: April 29, 2013, 04:15:18 AM
Ahh sorry, you're right. This is with knob all the way up:
Ground to left channel center pin = 100.4K
