Grid chokes at the input stage
xcortes · 7148
Offline xcortes
on: March 21, 2013, 09:14:45 PM
Who's tried grid chokes at the input stage? I think PB did at Hank's amps?
I imagine the risk for hum pickup is huge at that position?
Mike has recommended them in the past.
Any experiences?
« Last Edit: March 22, 2013, 03:13:29 AM by xcortes »
Xavier Cortes
Reply #1 on: March 22, 2013, 02:09:52 AM
Xavier,
You must be reading my mind -- I was going to ask this same question.  I'm guessing that the m3/4 cores would be best in this position because of the noise pickup issues you mention, but let's see what the wonks have to say.
Reply #2 on: March 22, 2013, 06:41:11 AM
I did indeed use them in Hank's amp, but I also knew that I had a 150 Ohm source driving them.
A grid choke is really the most useful when it is placed between grid and ground on a tube that may want some grid current while operating.
For a driver tube in a typical Bottlehead amp, you may find 1.5V-2.5V of bias with an input sensitivity of just under 1V, making the presence of abnormal grid current unlikely.
If we move up a stage to the grid of a DHT power tube, as we approach clipping, we may hit the 0V G/K line, and in attempting to operate beyond that line, the grid will be positive with respect to cathode, and grid current will be drawn.  The grid choke is a low impedance source of current for the grid if this happens, which allows the current to be drawn without shifting the bias.
