My take on the BeePre
johnsonad · 62367
Offline Paully
Reply #105 on: May 30, 2014, 08:26:23 AM
I am thinking that I would rather have four inputs and I have no need of the balanced out.  So I thought i would just move the regular RCA out over to the balanced out spot and sub in some more RCA jacks to gain another input.  I have been searching and have come up with "Neutrik D Style" as stated on the product page.  So basically I need this, right?
http://www.mouser.com/ProductDetail/Neutrik/NF2D-B-2/?qs=sGAEpiMZZMvlX3nhDDO4AENKlXxvJs2PoyYpzPF8P7w%3d
Offline johnsonad
Reply #106 on: May 30, 2014, 08:53:26 AM
That's it. I had a couple sitting around from a previous project. I use that second set of outputs to drive a SEX amp for headphones. You could use it for subs too.
Offline Paully
Reply #107 on: May 30, 2014, 09:02:23 AM
Yea, I was thinking whether or not I really want to go to another input or keep it a second output.  But I have four inputs I want to use and don't use a sub or any other secondary out (and I don't plan on upgrading my Altecs anytime soon to anything that would require a sub).  So another input might be a lot more helpful.  Though I do think about building a headphone amplifier someday.  Hmmm, decisions...
Reply #108 on: May 30, 2014, 09:53:32 AM
You'll also need a different rotary switch: a 4P4T.  This is generally a 2 level rotary switch, which gets pricey.
Offline Paully
Reply #109 on: May 30, 2014, 10:10:46 AM
Wow, you're right.  $100 and then you get started.  Thinking that a second RCA out is sounding better and better if not just wire it up as intended!  Thanks!
Offline johnsonad
Reply #110 on: May 30, 2014, 10:12:31 AM
I was thinking the same thing PB, that's a big ass switch.  Paully I rarely use a couple of sources and swap cables when needed.
Offline Paully
Reply #111 on: May 30, 2014, 10:16:09 AM
Just got off the phone with Grainger after talking though PB's post and that exact same thought occurred to me.  I use vinyl 99% of the time.  CD for most of the rest.  I do have a SACD player and an MP3 player.  Thinking if I need to switch between the two there is absolutely no way I use them enough to merit this sort of PIA and expense.  Think I will just swap them out manually when needed like you.  Its not that big of a deal.
Reply #112 on: May 30, 2014, 10:46:11 AM
You can also wire it completely stock and use a pair of these:
http://www.parts-express.com/xlr-female-to-rca-female-adapter--240-428
Offline Paully
Reply #113 on: May 30, 2014, 10:50:25 AM
That's cool, PB, even better idea then.  I am just going to wire the inputs and outputs stock.  Saves me some shipping and I get the adapters at Radio Shack or order them later.  Sweet!
Just out of curiosity, Johnsonad, what Elma selector switch did you use that still allowed the proper grounding scheme (if I understand the concept correctly)?
« Last Edit: May 30, 2014, 10:55:06 AM by Paully »
Offline johnsonad
Reply #114 on: May 30, 2014, 02:29:23 PM
I'll PM you this weekend Paully.  I suck at switches and the BH team would be able to tell you off the top of their collective heads.  I'm into a bottle of wine at the moment and don't want to risk flipping the BeePre until morning :)
Offline Paully
Reply #115 on: May 30, 2014, 02:34:46 PM
Enjoy the wine!  I have some seriously special beer upstairs, think I will go get some.  And I think we have a couple of weeks before I would need to know anything!
Edit: beer brewed by Trappist monks, and a Bottlehead Eros, Foreplay, and Paramounts feeding some Altec Model 19s.  Must be Friday night!  Too much fun!
« Last Edit: May 30, 2014, 02:43:43 PM by Paully »
Offline Skip Pack
Reply #116 on: May 31, 2014, 09:29:29 AM
A good alternative to a complex rotary switch is two 4pdt microswitches. Each of four (or three) inputs can be wired to the output bank of eyelets and the center eylets can be wired in parallel to the preamp circuit input. This switches four stereo inputs and grounds into the preamp. Michel Percy sells these for about $11 each, and they are quality switches (and very small). I've done these many times and it works very well.
Skip
Offline johnsonad
Reply #117 on: June 06, 2014, 12:24:43 PM
Thanks Skip, I'm going to give it a try on my next preamp build.
Offline Paully
Reply #118 on: June 27, 2014, 05:48:05 PM
Got it done, will post a picture with the big chokes on the chassis.  Sound was stunning.  Once again I was shocked by how much better something can make my system sound.  I didn't realize there was this much improvement left to be had.  The Bee Pre is magnificent.
« Last Edit: June 27, 2014, 05:56:53 PM by Paully »
Offline johnsonad
Reply #119 on: June 27, 2014, 08:16:49 PM
Well said! BH really got it right with that preamp
