Best place for switch for speakers
FraGGleR · 2461
Offline FraGGleR
on: March 30, 2013, 07:19:40 AM
Currently the speaker taps are not hooked up in my S.E.X. 2.1, but I want to see how well they work driving my bookshelf speakers.  I have a locking Neutrik jack and a Neutrik 4pin XLR jack installed for headphone use, neither of which have a built in switch.  From an impact on sound (if any), where in the chain would be the best place to place a simple switch?  I have the impedance boards and the C4S board in place, FYI.
Resonessence Concero -> Bottlehead S.E.X. 2.1 -> HD800
Reply #1 on: March 30, 2013, 07:29:15 AM
Switching at speaker level is the least offensive voltage level to work with.  Switching sources is much more critical.  So I would do it at the amplifier output, after the impedance switch and before the output connections.
Reply #2 on: March 30, 2013, 07:37:38 AM
I'd just unplug the headphones.
If you need to actually wire in the speaker posts, wire them to your 4 pin XLR jack.
Offline FraGGleR
Reply #3 on: March 30, 2013, 08:20:30 AM
It would definitely be simpler to do that.  Would it not be better to split from the output of the impedance board to reduce the length of the runs?  I will do whatever maintains the highest fidelity for the headphone jack since that is my primary listening method.
Reply #4 on: March 30, 2013, 08:22:42 AM
I don't think I would bother, but you could certainly try it both ways and let us know if you hear any difference (we do keep track of data like this).
