Stepper motor couch control for Stereomour
drewh1 · 2718
Offline drewh1
on: April 03, 2013, 12:22:46 PM
I just added the Bent audio stepper motor control. I took a little tweaking to get to fit, not quite plug and play. I am using the wall wart power supply and may eventually take power from the transformer, except that now I want to build the BeePre and move the Goldpoint to it! So I will leave this alone for awhile and enjoy my new power!
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Crack with Beyerdynamic T1
Reply #1 on: April 03, 2013, 12:52:13 PM
Nice looking.  Does the stepping motor go one step on the stepped attenuator at a time?
Offline drewh1
Reply #2 on: April 03, 2013, 02:34:18 PM
Yes - it is matched to the Goldpoint. You have to calibrate a bit at first but then it works fine. I really like it, no negatives if you don't mind the click when you change volumes.  I don't usually move it more than a click or two at a time.
My plan is to build a BeePre, then Paramounts. I will move it over to the BeePre then.  Oh - you might need a slightly deeper base than the stock wooden ones from Bottlehead, not sure, I have to measure it. (we all want deeper bass though right?)
drew.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Reply #3 on: April 04, 2013, 12:13:26 AM
About 10 years ago I bought a Creek OBH-10.  It is a motorized pot with inputs and outputs.  I was about 16 feet away from the FP 2 and got tired of making small adjustments.  Ok, I'm lazy!  But it is awfully convenient.  I have referred a number of Bottleheads to BentAudio.
Offline drewh1
Reply #4 on: April 04, 2013, 05:19:02 AM
wow Grainger, you either stay up very late or wake up very early!
You know, I don't think it is really about laziness. There is usually an optimal listening volume in the mix or with your equipment. I have found that with all my amps.  The real issue though is the different levels of the recordings. I have all of my music on a computer server, from 16/44 khz to 24/192. I find the Redbook to have much higher levels than most of the hi res stuff. The 24/48 khz recordings seem to have very low levels, maybe 6db down from everything else. So it is not always a minor adjustment.
So, I can't see any reason not to have a remote in this day and age - although some people like a clutch and stick shift, I would never own a car with one again.
drew
Ayre QB-9 USB DAC
Kaiju
Stereoumour
