Taking orders :)
xcortes · 240543
0 Members and 19 Guests are viewing this topic.
Reply #165 on: November 01, 2013, 08:12:08 AM
We have worked out what should be the final small revisions to the DAC board. John will be working on getting these turned into a final prototype board in the next few weeks. Our battery supply test is on hold for a bit as we have had a setback with the existing prototype due to my trying to kludge together some temporary cables that seem to have killed our existing prototype. Yes, it was a very clever $1500 mistake that has thrown us behind maybe another four weeks. And people are always saying to me, "Doc your job must be so fun."
Reply #166 on: November 01, 2013, 08:54:59 AM
Sam,
Just set the forum as your home page (I did).  Then when you open your browser click on Unread Topics.  If there is an update it will show up there
« Last Edit: February 22, 2014, 09:50:20 AM by Grainger49 »
Offline denti alligator
Reply #167 on: November 01, 2013, 11:19:54 AM
Sam,
I do use the unread topics thread, but is find myself lying in wait for new posts. That's what I mean by anticipation. Lol
- Sam
Reply #168 on: November 01, 2013, 01:09:56 PM
Hey Doc, I have a battery supply for another project. It uses a CTEK US 800 charger to keep the battery topped up, it works very well...John
Offline tdogzthmn
  • Industrial Designer
Reply #169 on: November 10, 2013, 02:31:12 PM
What is the purpose of the batteries in the DAC circuit?
Reply #170 on: November 10, 2013, 02:42:31 PM
It eliminates all AC.  AC can cause hum.  The electronics run on DC anyway.
« Last Edit: February 22, 2014, 09:50:34 AM by Grainger49 »
Reply #171 on: November 10, 2013, 03:51:55 PM
The battery so far has sounded much better than the other supplies we have tried.
Reply #172 on: November 11, 2013, 03:48:41 AM
Assuming you are using a battery as a cleaner power source, how you are going to implement a charging circuit without introducing the noise you were trying to avoid in the first place?    I'm sure there is a simple way to do it, i'm just curious to learn...
Reply #173 on: November 11, 2013, 04:22:56 AM
The on/off switch changes from disconnected from the charger (on) to connected to the charger (off).
« Last Edit: February 22, 2014, 09:50:53 AM by Grainger49 »
Reply #174 on: November 11, 2013, 04:45:36 AM
Ok, that made me laugh out loud. What's that saying again "keep it simple, stupid" :)
Reply #175 on: November 11, 2013, 02:37:58 PM
I have an Ack! dAck! that has a four pole double position power switch.  In the on position the two 12V batteries supply plus and minus 12V to the DAC, the charging circuit is totally disconnected.  In the off position it connects the batteries in parallel and to the charger, the DAC circuit is disconnected.
You asked a technical question.  It takes a technical answer.
« Last Edit: February 22, 2014, 09:51:09 AM by Grainger49 »
Reply #176 on: November 12, 2013, 04:17:02 AM
Thanks Grainger, i understood you the first time, my comment was in reference to the elegant simplicity of the solution.
My mind was trying to devise clever circuitry to separate the charging supply from the output when the answer was a DPDT switch, hence keep it simple.. :)
Reply #177 on: November 12, 2013, 06:31:24 AM
Sorry!
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2FCorrected.gif&hash=89e1a80c0c6be2c0ddb28d3813ea9c4aaafdfcb2)
« Last Edit: February 22, 2014, 09:51:27 AM by Grainger49 »
Reply #178 on: November 13, 2013, 12:41:29 AM
Not at all, thank you for be so helpful ;)
Reply #179 on: November 15, 2013, 03:21:07 PM
Well, thankfully John saved my a** by managing to repair the prototype board we blew last week. We're still not taking orders, but here is a photo of the most recent prototype that we have been playing with. This is 90% of the way to what the final will look like, save for some changes to the positioning of the various ports and slots. The panel is 6" square. The light at the front is the charging light. When on, unit is charging, when off, battery is fully charged. The switches are on/charge, USB/SPDIF coax/TOSLINK, and filter selection (that on the chip or John's awesome sounding software filter). The little slot behind that is where the optional sample rate display goes. That's a heat sink for the charging circuit at the left center, The screw heads in the middle hold the battery under the chassis, and I think the rest of the stuff is pretty self explanatory. Some of this may shift around and there will be one more slot for "accessories" to be determined in the future - that's why I say it's 90% like the finished version.
Good news is that it sounds quite good even with the charging circuit active. Great news is it sounds fabulous running off battery only. We are exploring the notion of a standby mode that keeps the board on and warmed up while the battery trickle charges, for those who like to keep their SS gear on all the time, and possibly a fast charge mode for those who are impatient and don't mind replacing the SLA battery more often.
