Taking orders :)
xcortes · 242009
Offline John Swenson
Reply #45 on: April 16, 2013, 02:41:34 PM
Yes, 24/192 will work over S/PDIF coax. I'm using the fastest TOSLINK receiver I can get, which should allow 192 via optical, IF the transport supports it.
Many devices use the cheaper slower optical modules which won't work for 192, so many transport designers limited their optical out to 96. So IF yours supports 192 over optical it should work as well.
John Swenson
DAC designer
Moded Squeezebox->DIY DAC
Offline tdogzthmn
  • Industrial Designer
Reply #46 on: April 17, 2013, 12:16:19 PM
Support for Interger Mode would be nice too, many of the audiophile players now have the ability to utilize DAC's which support it.
Offline xcortes
Reply #47 on: April 21, 2013, 03:37:09 PM
Quote
Wasn't really a matter of getting rid of the transformers. I just did a lot of listening to transformer vs. resistor and found that the bass was a lot better to my ear with the resistor, and the mid and treble sounded very close
At the very beginning of this project John Swenson mentioned the transformers worked very well as low pass filters. May i ask if the current iteration is completely filterless or are you implementing some analog filter?
Xavier Cortes
Reply #48 on: April 21, 2013, 05:08:19 PM
The version we are using this week uses a cap as a simple 1st order filter. I found, as usual, that a line level transformer didn't give me the best bass.
Offline xcortes
Reply #49 on: April 21, 2013, 05:20:49 PM
"The version we are using this week". Classic!
Xavier Cortes
Reply #50 on: April 30, 2013, 09:56:16 AM
John shot me an email last week with a status report. Looks like about four weeks before we have a prototype of the latest version running.
Offline Chris
Reply #51 on: April 30, 2013, 10:40:22 AM
Sounds like some premium parts are going into this thing like the BeePre.. I like it...
Offline ssssly
Reply #52 on: May 01, 2013, 12:15:35 AM
Forgive me if it has already been answered and I missed it.
Will the USB input be asynchronous?
Reply #53 on: May 01, 2013, 04:42:29 AM
I'm away from my notes today. There are two pretty big windfalls in my yard that have been there for weeks, PB loaned me a chainsaw, and it's sunny, so I'll be playing gardener today. I believe that John has something he feels is a superior way to deal with USB and hopefully he will weigh in on that when he has some free time.
Offline tdogzthmn
Reply #54 on: May 02, 2013, 07:47:31 AM
Has a list of all the supported sample rates been posted?  I cant remember seeing them all listed yet.
Offline BNAL
Reply #55 on: May 02, 2013, 11:36:14 AM
John has posted that the DAC will support rates up to 24/192 via USB and coaxial. As for optical he is working on supporting the same rate, but that does not seem to be confirmed. Not sure about the other sample rates.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline tdogzthmn
Reply #56 on: May 03, 2013, 07:15:25 AM
The most common sampling rates are: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz and 192 kHz.  I had wanted to know if all of these are supported since I own digital files for each of the above and hoping the DAC can handle them with having to upsample to 192 kHz.
Reply #57 on: May 03, 2013, 08:05:53 AM
Yes, it will be able to do all of those sample rates as well as 176.4
Offline tdogzthmn
Reply #58 on: May 07, 2013, 08:37:22 AM
i've been looking into making my 2 channel setup into a 5.1 and it looks like this DAC will be capable of playing back my multi channel files.  Would I need to purchase 5 separate kits to do this?
Reply #59 on: May 07, 2013, 08:50:24 AM
It's a stereo DAC, so for six channels you would need three kits. Be advised that it may be a while before we have this ability to parallel three or four DACs available, i.e. it may not be ready in the first release. The beauty of the auxilary port that John mentioned is that we can add new features as we have time to develop them and use that port to implement them.
