Suggestions That Won't Cost An Arm Or Leg
Grainger49 · 6267
on: April 04, 2013, 01:19:00 PM
I am back at work and want to upgrade the $17 Obbligato Parafeed caps in my Paramours.  I have an iron upgrade and need 10uF@600 or greater volts.
The Clarity MR have been well received.  They are $133 each.  That is steep but I can probably bring my cheap self to do it.
Any other suggestions?
Offline ssssly
Reply #1 on: April 04, 2013, 01:45:00 PM
Could go with the Duelund. Bigger than a Coke can and about $650  :D
Seriously, the Mundorf Supremes in that value are around $50 and very good sounding caps. Their silver in oil is also a very nice sounding, bit smoother to my ear, and isn't much more at around $190.
Haven't compared either to the Clarity but would consider either a step up from the Obbligato. Which is a nice sounding cap to begin with.
Enjoy
Offline debk
Reply #2 on: April 04, 2013, 01:55:41 PM
Grainger
I really like the Clarity MR.
I have a pair of the newer Solen Silver capacitor in 10uf I am not using, you can have if you want to try them.  PM off list and I will send them to you if you want them.
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline coca
Reply #3 on: April 04, 2013, 02:08:56 PM
Grainger, go to the Parts Connexion sight and on the opening page click on the capacitor shoot-out review when it rolls up. Lots of great information there.
Bernie.
Offline earwaxxer
Reply #4 on: April 04, 2013, 03:13:05 PM
Hey Granger - I understand your dilemma - I have some obbligatos just like probably everyone else. I have had them in crossovers etc. ended up taking them out. Not very sophisticated sounding IMO. They supposedly get their films from Germany. I say, cut out the middle man, go with German caps from a company that knows what they are doing - you guessed it - Mundorf. In the 10uf I would go with the Supremes - $50/ each. You can always use them somewhere else (crossover) if they dont fit the electronics bill. If you like the basic sound it will give you a clear upgrade path - hint, hint - silver/oils!
Eric
Reply #5 on: April 04, 2013, 03:18:37 PM
Damn, lost my post. Short version, I am in the same boat with my SR-75 rebuild...John
Offline Alonzo
Reply #6 on: April 04, 2013, 04:31:37 PM
How about just bypassing the oilers with a 1 uf Mundorf evo silver/gold and oil?  Also the 1uf Supreme would be good.  I have supremes bypasses in my 45 amp that has obligatto golds and evo bypasses in my 2a3 amp (with obligatto oilers) I like what the obliggatos do and the supposedly higher quality bypasses just add to the goodness.
Alonzo
Reply #7 on: April 04, 2013, 05:52:37 PM
Have you guys listened with and without the bypass? I'm old and rusty math-wise but I think maybe you can do some math that indicates there might be phase differentials between the two caps that could actually make the sound less coherent. Not trying to make a stand, just suggesting we might as a community want to cook up some tests to help determine the validity of paralleled caps of an order of magnitude or more difference in capacitance. I have done some rudimentary listening tests along these lines many years ago that made me shy away from the approach.
Offline ssssly
Reply #8 on: April 04, 2013, 06:34:13 PM
I have never left the bypass caps that I have tried in for very long.
They certainly changed the sound. But to me they seemed to either add or subtract in a very limited frequency range. Like a hump in a poorly designed crossover.
I do know people who love them though. I tend to like very flat response curves though. And many find the sound I prefer to be rather dry (alla AKG 702s).
Offline Alonzo
Reply #9 on: April 04, 2013, 06:37:30 PM
Doc,
I didn't go the math route, I just took some caps that I broke in using Grainger's rapid-fire method and added them.  I liked the way it sounded so I left them in the amps.  Best part about it is that it sounds good for a minimal amount of work and it's cheaper.  It may be placebo but that really doesn't matter if I like the sound...
Alonzo
Offline earwaxxer
Reply #10 on: April 04, 2013, 06:37:42 PM
From what I can gather, in the world of audiophiledome, cap bypassing is still in the realm of 'alchemy' compared to other more established disciplines such as power supplies, output stages etc. I have dallied in it a tad with my speaker crossovers. I tried bypassing three different brands of large caps with a small value Mundorf silver/oil and the only one that sounded better (actually much better) was a paper/oil. It was trial/error. It seems what most people do is buy a .01uf ultra expensive cap - ex. CuTF V-cap - use it as a bypass and hope for the best. Of course the reviews are most always 'glowing'. I remain a skeptic.
Eric
Reply #11 on: April 06, 2013, 02:45:17 AM
Ok, I
