Paramounts testing voltages
docbob52 · 2291
Offline docbob52
on: April 04, 2013, 01:49:04 PM
I fel like a dummy, but what is the best way to support and invert the paramounts to allow access to the terminals to check live voltages without damaging the tubes?  Inverting them in the wood bases does not allow enough room.
Garrard 301/ high mass plinth, SME 312S tonearm/ Sleeping beauty cartridge/ Denon AU 320SUT. Transcendent audio GG preamp and OTL SOB power amp. Blumenstein Orca/Dungeness Speakers
Second system.  BH Paramount 300B amps.  BeePre.  Sony SCD777ES, Wyred4 sound Dac. Mac mini.
Reply #1 on: April 04, 2013, 03:33:40 PM
I look for a cardboard box of about the right size. Fold out the flaps and wind a loop or two of tape around them to stiffen it up.
Don't forget for many amps seting them down at something like 45 deg or whatever  is the best way...John
Offline kgoss
Reply #2 on: April 04, 2013, 03:53:36 PM
I would put something solid like wood or books under the ends of the base to raise it enough for the 300B to clear and then put the amp in the base upside down.  That would give you a solid platform to do measurements on.  Like John said, you could scotch the amp on its side, but I think this would be difficult to do without putting side pressure on the 300B tube.
Ken
Ken Goss
Offline ssssly
Reply #3 on: April 04, 2013, 05:04:56 PM
The paramount iron is big enough that if you put a paperback under the tranny you just balance it that way.
Is way more stable to prop the base up on something though. Books or some 2x4s. Don't really need much.
Offline docbob52
Reply #4 on: April 05, 2013, 02:02:23 AM
Thanks so much. Great ideas!
Offline STURMJ
Reply #5 on: April 06, 2013, 02:35:31 AM
When I was testing mine, I happened to have a nice piece of molded packing styrofoam lying around.  Worked perfect.
