resistance checks
KevO · 4146
Offline KevO
on: April 07, 2013, 06:17:35 PM
Greetings forum gurus.
 Please forgive my ignorance regarding resistance results.
1. The manual says terminal 1 and 16 should start high and drop to 4 ohms. I just get 4 ohms. Fine right?
2. Terminal 7 and 12 should measure 470k and I get only 455k on 7, but a fine 472k on 12. Should I replace the resistor on 7 or is that within tolerance?
3. Terminals 10 and 15 are supposed to start low and work up to 20k+  but I read about 290k and it very slowly drops. Is that an issue?
4. C4 and C5 read the same - about 2.8M and D4 and D5 read the same - about 1.1M. Is that OK?
All the other readings seem OK. Just want to verify before power testing.
Thank you!!
-Kevin
« Last Edit: April 08, 2013, 09:43:32 AM by KevO »
Reply #1 on: April 08, 2013, 10:53:27 AM
I'd go ahead and power it up, some of the resistance behaviors will vary a bit based on the meter used.
The 455k vs. 472k shouldn't present any problems.
Offline KevO
Reply #2 on: April 08, 2013, 11:14:08 AM
Thanks PB!
